First post the code that you have, following the guidelines for posting code in the "how to use this forum-please read" sticky. Then we can help to make the code work like you want.
int timer = 100; // The higher the number, the slower the timing.
// use a for loop to initialize each pin as an output:
for (int thisPin = 3; thisPin < 13; thisPin++) {
pinMode(thisPin, OUTPUT);
// loop from the lowest pin to the highest:
// turn the pin on:
digitalWrite(thisPin, HIGH);
delay(timer);
// turn the pin off:
digitalWrite(thisPin, LOW);
// loop from the highest pin to the lowest:
for (int thisPin = 12; thisPin >= 3; thisPin--) {
// turn the pin on:
delay(timer);
So it's the 'timer' value the determines how fast the LEDs move. Change 'timer' in the pattern of your choice.
Maybe you could put each cycle in a function and call the function with different values of timer.
Like this:
// Speed up over 25 cycles, delays of 100 to 50
for (int timer = 100; timer > 50; timer -= 2)
oneCycle(timer);
// Slow down over 25 cycles, delays of 50 to 100
for (int timer = 50; timer < 100; timer += 2)
oneCycle(timer);
void oneCycle(int delayTime)
// turn the pin on:
delay(delayTime);
// turn the pin on:
delay(delayTime);
You could put the predefined times in an array. This allows any times that you want (not necessarily even multiples nor sequential order). In loop make an index variable the increments each time through loop. Use the index to select which element of the array gets put into the timer variable. When the index reaches the end of the array reset the index to 0 to repeat.
unsigned int times[] = {100, 200, 300, 400, 500, 400, 300, 200, 100};
int numberOfTimes;
numberOfTimes = sizeof(times) / sizeof(times[0]);
static int index = 0;
timer = times[index];
index++;
if (index >= numberOfTimes)
index = 0;
// turn the pin on:
delay(timer);
// turn the pin on:
delay(timer);
