Speedo car  de-limiter help
Good day to you all,
I want to use my arduino to overcome the speed limiter on my car. I've worked out the speedo at the back emited a gound pulse directly into the ECU. If the pulse is say > than 111mph the ECU shuts down. What I would like to do is duplicate the pulse upto say 100 then freeze it at that.
I am using the arduino for other things so I've already coded in an attachInterrupt which monitors pin2 can works out the length inbetween the pulses. How would I configure the arduino to output the same negitive pulse but throttle it so it doesnt go over the 100 needed ?
Many thanks
Steve
Do you mind me asking where you live?
It's just that, I don't want to be on the same road as you when you're driving your hacked auto.
Preferably in a different country.
yeah you can ask.. :slight_smile:
The codes for a kitcar...
I will suss it.. just thought someone might have already done it. I have it reading out now in mph just need to generate a pulse now to match the input, cant be that hard :slight_smile:
Steve
OK, you said "mph", so I think I'm OK.
