Speedometer code
I have found a simple speedometer that I would like to make.
When I copy and paste the code from the site. http://www.instructables.com/id/Measure-RPM-DIY-Portable-Digital-Tachometer/
CODE:
#include<ShiftLCD.h>
ShiftLCD lcd(8,10,9); // DEFINE LCD PINS
volatile byte REV; // VOLATILE DATA TYPE TO STORE REVOLUTIONS
unsigned long int rpm, maxRPM; // DEFINE RPM AND MAXIMUM RPM
unsigned long time; // DEFINE TIME TAKEN TO COVER ONE REVOLUTION
int ledPin = 12; // STATUS LED
int led = 0,RPMlen , prevRPM; // INTEGERS TO STORE LED VALUE AND CURRENT RPM AND PREVIOUS RPM
int flag = 0; // A VARIABLE TO DETERMINE WHETHER THE LCD NEEDS TO BE CLEARED OR NOT
long prevtime = 0; // STORE IDLE TIME TO TOGGLE MENU
Serial.begin(9600); // GET VALUES USING SERIAL MONITOR
lcd.begin(16, 2); // INITIATE LCD
attachInterrupt(0, RPMCount, RISING); // ADD A HIGH PRIORITY ACTION ( AN INTERRUPT) WHEN THE SENSOR GOES FROM LOW TO HIGH
REV = 0; // START ALL THE VARIABLES FROM 0
rpm = 0;
time = 0;
pinMode(ledPin, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
digitalWrite(3, HIGH); // VCC PIN FOR SENSOR
digitalWrite(4, LOW); // GND PIN FOR SENSOR
lcd.print("TACHOMETER"); // STARTUP TEXT
lcd.setCursor(0, 1);
lcd.print("- ELECTRO18"); // THAT'S ME
delay(2000);
lcd.clear();
long currtime = millis(); // GET CURRENT TIME
long idletime = currtime - prevtime; // CALCULATE IDLE TIME
if(REV >= 5 ) // IT WILL UPDATE AFETR EVERY 5 READINGS
if(flag==0) // CLEAR THE LCD TO AVOID ANY GARBAGE TEXT
lcd.clear();
lcd.print("SENSOR MEASURING");
flag=1; // AFTER FLAG = 1 , THE LOOP WILL NOT EXECUTE AGAIN
rpm = 30*1000/(millis() - time)*REV; // CALCULATE RPM USING REVOLUTIONS AND ELAPSED TIME
if(rpm > maxRPM)
maxRPM = rpm; // GET THE MAX RPM THROUGHOUT THE RUN
time = millis();
REV = 0;
int x= rpm; // CALCULATE NUMBER OF DIGITS IN RPM
while(x!=0)
x = x/10;
RPMlen++;
if(RPMlen!=prevRPM) // IF THE RPM FALLS TO A LOWER NUMBER WITH LESS DIGITS , THE LCD WILL GET CLEARED
lcd.clear();
prevRPM = RPMlen;
flag=0;
lcd.print(rpm,DEC); // PRINT RPM IN DECIMAL SYSTEM
lcd.setCursor(6,1);
lcd.print("RPM");
prevtime = currtime; // RESET IDLETIME
if(idletime > 5000 ) // IF THERE ARE NO READING FOR 5 SEC , THE SCREEN WILL SHOW MAX RPM
if(flag==1) // CLEAR THE LCD
lcd.clear();
flag=0;
lcd.clear();
lcd.print("MAXIMUM RPM");
lcd.print(maxRPM,DEC); // DISPLAY MAX RPM
lcd.print(" RPM");
delay(2000);
lcd.clear();
lcd.print("IDLE STATE");
lcd.print("READY TO MEASURE");
delay(2000);
void RPMCount() // EVERYTIME WHEN THE SENSOR GOES FROM LOW TO HIGH , THIS FUNCTION WILL BE INVOKED
REV++; // INCREASE REVOLUTIONS
if (led == LOW)
led = HIGH; // TOGGLE STATUS LED
led = LOW;
digitalWrite(ledPin, led);
////////////////////////////////////////////////////////////// END OF THE PROGRAM ///////////////////////////////////////////////////////////////////////
And this error message comes up.
sketch_sep22a:3: error: 'ShiftLCD' does not name a type
sketch_sep22a.ino: In function 'void setup()':
sketch_sep22a:23: error: 'lcd' was not declared in this scope
sketch_sep22a.ino: In function 'void loop()':
sketch_sep22a:63: error: 'lcd' was not declared in this scope
sketch_sep22a:88: error: 'lcd' was not declared in this scope
sketch_sep22a:94: error: 'lcd' was not declared in this scope
sketch_sep22a:110: error: 'lcd' was not declared in this scope
sketch_sep22a:114: error: 'lcd' was not declared in this scope
Please can someone tell me how I can make this code work!
Thanks
Cam
please follow the guidelines how to post code
use CTRL-T in the IDE to reformat the code and use code tags please - #button above smileys
Would need more information of precisely which part you are struggling with.
You need to download and install the ShiftLCD library as well!
Check out his thread on issues with the ShiftLCD library. http://forum.arduino.cc/index.php/topic,99264.0.html
Do you really want to use a shift register to control the LCD in your project, or did you not realize what the instructables example used for hardware?
