I have this prodject "Working" just need some advice on how to approach a few issues.
Just sitting at idle from start up I am getting very erratic results in my display anywhere from 11 to 150 mph just at idle.
I am using pulseIn to measure the timing of the pulses then calculate the speed.
I am beginning to think pulseIn is to sensitive for what I am using it for?
It also appears that I need some form of averaging readings out but it is obvious I need to get stable readings first. I seem to be having a noise problem.
Is there some smarter way of pulling this off or any advice on how to to clean up my readings?
#include <WiseChipHUD.h>
// Notes
// built around a sparkfun redbord turbo
// vhicle is set to 4000 PPM square wave pulse 0-5v
// PPM = Pulses Per Mile
// mesuring the time between pulses in micro seconds
// vss input pin = 12
// maxamum display number is 199
WiseChipHUD myHUD; //sets up myHUD
unsigned long VSS; // vhucle speed sensor input
int MPH;
pinMode(12, INPUT);
myHUD.begin(); // sets up myHUD
SerialUSB.begin(9600);
delay(3000);// delay to get car started and running
myHUD.clearAll();// clears all segments
//while (!SerialUSB); //===================================================debug code requires moniter to be open before continung =======================
// cool start up sequince for display
for (int i = 0; i< 199; i += 5) {
//myHUD.setTirePressure(i, 1);
myHUD.setSpeedometer(i); }
myHUD.clearAll(); //clears start up display
myHUD.setSpeedometer(0); // sets redings to zero
VSS = pulseIn(12, HIGH, 10000000); // IF NO PULSES IN 10 SECONDS TIME OUT and return zero mesured in microseconds
//VSS = 12345;// ==========Testing Code will simulate VSS signal should be 72 mph COMMENT ME OUT!!!!!=======================
if (VSS != 0) // changed to VSS from MPH change back if nessary
MPH = 900000/VSS;// math for microsconds to mph
if (VSS == 0)
MPH = 0;
if (MPH > 199)
MPH = 0;
abs(MPH); // round down to the nerist whole number
//===================================================Serial====================================================
SerialUSB.println("VSS Times Microseconds");
SerialUSB.println(VSS, DEC); // send data over usb serial connection
SerialUSB.println("MPH");
SerialUSB.println(MPH, DEC);
//=================================================Dispay======================================================
myHUD.setSpeedometer(MPH);//sets display to calculated number
}// end of void loop
Small output of the serial monitor from idle
12420
MPH
72
3880
MPH
0
71913
MPH
12
29622
MPH
30
37831
MPH
23
76486
MPH
11
57869
MPH
15
79062
MPH
11
Thanks for having a look Hive mind of the interwebs
