Speedometer With GPS and GSM Modules Issue
Hello Everyone...
I am basically trying to make a speedometer using a GPS Module, and then send an sms message through the GSM Module if certain speed is exceeded.
I used the code attached, but I faced the following error: Error compiling for board Arduino/Genuino Uno.
Can anyone help me solve the problem.
the error code is:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\GSM\src/GSM.h:46:0,
                 from C:\Users\awss\Documents\Arduino\intergration1\intergration1.ino:5:
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\GSM\src/GSM3ShieldV1BandManagement.h:49:1: warning: 'typedef' was ignored in this declaration
 typedef enum GSM3GSMBand {UNDEFINED, EGSM_MODE, DCS_MODE, PCS_MODE, EGSM_DCS_MODE, GSM850_PCS_MODE, GSM850_EGSM_DCS_PCS_MODE};
C:\Users\awss\Documents\Arduino\intergration1\intergration1.ino: In function 'boolean gsmmessage()':
C:\Users\awss\Documents\Arduino\intergration1\intergration1.ino:67:20: warning: invalid conversion from 'const char*' to 'char' [-fpermissive]
   char remoteNum = "966.....";  // telephone number to send sms
C:\Users\awss\Documents\Arduino\intergration1\intergration1.ino:68:17: warning: invalid conversion from 'const char*' to 'char' [-fpermissive]
   char txtMsg = "You car is speeding...";
C:\Users\awss\Documents\Arduino\intergration1\intergration1.ino:69:25: warning: invalid conversion from 'char' to 'const char*' [-fpermissive]
   sms.beginSMS(remoteNum);
In file included from C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\GSM\src/GSM.h:53:0,
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\libraries\GSM\src/GSM3SMSService.h:69:7: note:   initializing argument 1 of 'int GSM3SMSService::beginSMS(const char*)'
   int beginSMS(const char* to);
libraries\GSM\GSM3SoftSerial.cpp.o (symbol from plugin): In function `GSM3SoftSerial::spaceAvailable()':
(.text+0x0): multiple definition of `__vector_3'
libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_4'
(.text+0x0): multiple definition of `__vector_5'
collect2.exe: error: ld returned 1 exit status
exit status 1
option enabled in File -> Preferences.
#include <math.h> //math library to use for round function
#include <SoftwareSerial.h>
#include <TinyGPS++.h>
#include <LiquidCrystal.h>
#include <GSM.h>
//TinyGPS gps; //create a gps object
TinyGPSPlus gps;
GSM gsmAccess;
GSM_SMS sms;
#define PINNUMBER 2
float fLat, fLong; //floats for longitude and latitude; will be used to determine whether the GPS data is up to date or not
unsigned long fix_age; // returns +- latitude/longitude in degrees
const int rs = 12, en = 13, d4 = 9, d5 = 10, d6 = 6, d7 = 8;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
SoftwareSerial ss(5, 4);
  Serial.begin(9600); //start the serial communication
  lcd.begin(20, 4);
  ss.begin(9600);
  while (ss.available() > 0)
    gps.encode(ss.read());
          if (gps.location.isUpdated())
      lcd.print("                     speedKmph= ");
      lcd.print(gps.speed.kmph());
      lcd.print("                     speedmps= ");
      lcd.print(gps.speed.mps());
      lcd.clear();
  while ( 3 < gps.speed.mps() <10 )
   gsmmessage();
   while (ss.available() == 0)
   {lcd.print("                     No GPS Connection ");
   lcd.clear();
  sms.print(txtMsg);
  sms.endSMS();
intergration1.ino (1.5 KB)
I cannot open ino files on my device. More members will see your code if you post it according to the forum guidelines. Following the guidelines will get you better help faster.
When you have errors, post the entire text of the error message. Paraphrasing the message leave out much important information. It is easy to post the error. In the IDE there is a "copy error" button (lower right of the IDE window). Copy the error and paste the error into a post in code tags.
  sms.print(txtMsg);
  sms.endSMS();
You can't store a character pointer in a character. Did you mean to use character pointers or character arrays?
  const char * remoteNum = "966.....";  // telephone number to send sms
  const char * txtMsg = "You car is speeding...";
 char remoteNum[] = "966.....";  // telephone number to send sms
  char txtMsg[] = "You car is speeding...";
Or you could just use the string constants directly:
  sms.beginSMS("966.....");
  sms.print( "You car is speeding...");
  sms.endSMS();
The GSM library has its own built-in GSMSoftSerial so it can't be used with SoftwareSerial due to interrupt conflicts:
I would try an Arduino Micro which has built-in USB, leaving Serial1 free. You could then use Serial1 for GPS and the GSM library's GSMSoftSerial for the GSM module.
johnwasser:
Thanks that was the reason of the problem, I deleted the software serial, and I can unplug the GPS pins during uploading the code. However, the problem I am facing now is that serial 1 is used for both the lcd display and the GPS, which causes conflict. Do you have a workaround that avoids software serial.
Abdulazizhd:
The LCD should not be using a serial connection at all. It appears to be using pins 6, 8, 9, 10, 12, and 13.
Could you post your new sketch (after Tools->Auto Format, of course)?
If you need more than two serial ports (Serial/Serial1 + SoftwareSerial/GSMSoftSerial) you should probably upgrade to an Arduino MEGA which has FOUR hardware serial ports: Serial, Serial1, Serial2, Serial3.
johnwasser:
//#include <SoftwareSerial.h>
#include <GSM.h>
#include <GSM3SoftSerial.h>
TinyGPSPlus gps;
GSM gsmAccess;
GSM_SMS sms;
#define PINNUMBER "4843"
//SoftwareSerial ss(5, 4);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("SMS Messages Sender");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while (notConnected) {
    if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
      notConnected = false;
      Serial.println("Not connected");
    Serial2.begin(9600);
    lcd.begin(20, 4);
  while (Serial2.available() > 0)
    gps.encode(Serial2.read());
      lcd.clear();
      while ( 3 < gps.speed.mps() < 10 )
        gsmmessage();
  while (Serial2.available() == 0)
    lcd.clear();
boolean gsmmessage() {
  boolean gsmm;
  sms.beginSMS("9660000000");
  sms.endSMS();
  return gsmm;
  while (!Serial)
You're supposed to call Serial.begin() BEFORE you use the Serial port.
So... Arduino MEGA?
        gsmmessage();
That is NOT how you compare against a range. This isn't Fortran. Are you SURE you want a WHILE loop so it continues to seen the same SMS message forever? I think an 'if' would be better.
     if (gps.speed.mps() > 3 && gps.speed.mps() < 10)
        gsmmessage();
