I have finally tucked my tail and need ask for some help. I have spent hours trying to troubleshoot my code and just can't seem to figure out. I have been using this code successfully for over a year now, but recently decided to expand the functionality. So here is some quick background.
The code reads data from the serial port (sent from a Victron MPPT controller). The data is formatted like this "TAGVALUE". It then takes the values we are interested in and displays the value on an LCD and to the serial port. Some of the code was borrowed from another user, but is pretty much a clone of the serial data tutorial. Anyway here is the code.
// include the library code
#include <Wire.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); // RX, TX
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
int CS1;
float V2, I2, VPV2;
const byte numChars = 30;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
const char * labelsOfInterest[] = {"V", "I", "VPV", "PPV", "CS"};
const unsigned int maxLabelsOfInterest = sizeof(labelsOfInterest) / sizeof(*labelsOfInterest);
boolean sleep1 = false;
Serial.begin(19200);
mySerial.begin(19200);
lcd.init(); //initialize the lcd
lcd.backlight(); //open the backlight
lcd.setCursor(0,0);
lcd.print("INIT");
//lcd.setCursor(0,0);
//lcd.print("INIT");
recvWithEndMarker();
if (newData) { // we have received a ful line, deal with it
parseNewData(); // this messes up receivedChars[]
newData = false;
void recvWithEndMarker() {
static byte ndx = 0;
char endMarker = '\n';
char rc;
while (mySerial.available() > 0 && newData == false) {
rc = mySerial.read();
if (rc != '\r') { // we ignore that character
if (rc != endMarker) {
if (rc == '\t') rc = ' '; // change tabs into just a space
receivedChars[ndx] = rc;
ndx++; // we go to the next space in our buffer
if (ndx >= numChars) { // and check bounds.
ndx = numChars - 1; // that means we will loose the end of long strings
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0; // ndx is static, so we prepare for next turn
newData = true;
void parseNewData()
const char *delim = " ";
char * item;
boolean labelFound;
long int labelValue;
int labelIndex;
item = strtok (receivedChars, delim);
labelFound = false;
for (int i = 0; i < maxLabelsOfInterest; ++i) {
if (!strcmp(labelsOfInterest[i], item)) {
item = strtok(NULL, delim);
if (item != NULL) {
labelFound = true;
labelIndex = i;
labelValue = atol(item);
break; // ends the for loop as we found a label
} // end if we had a value for the label
} // end string compare
} // end for
if (labelFound) {
switch (labelIndex) {
case 0:
lcd.setCursor(0,0);
V2 = labelValue / 1000.00f;
Serial.print("Battery Volate = ");
Serial.println(V2);
lcd.print("BV=");
lcd.print(V2);
case 1:
I2 = labelValue / 1000.00f;
if (I2 < 0.05) {
lcd.setCursor(0,1);
lcd.print(" SLEEP ");
Serial.println("Charger Sleeping ");
sleep1=true;
else {
Serial.print("Current Into Batts = ");
Serial.println(I2);
lcd.setCursor(0,1);
lcd.print("BC=");
lcd.print(I2);
lcd.print(" ");
sleep1=false;
case 2:
VPV2 = labelValue / 1000.0f;
if (sleep1 == true) {
Serial.println("Panels Sleeping ");
else {
Serial.print("Panel Voltage = ");
Serial.println(VPV2);
lcd.setCursor(9,1);
lcd.print("PV=");
lcd.print(VPV2);
case 3:
Serial.print("Panel Wattage = ");
Serial.println(labelValue);
lcd.setCursor(12,0);
lcd.print(" ");
lcd.setCursor(9,0);
lcd.print("PW=");
lcd.print(labelValue);
case 4:
CS1=labelValue;
switch (CS1) {
case 0:
Serial.println("Charger is OFF");
lcd.setCursor(15,0);
lcd.print(" ");
CS1 = NULL;
case 1:
Serial.println("Charger is in low power mode");
lcd.print("S");
CS1 = NULL;
case 2:
Serial.println("Charger has a fault");
lcd.print("E");
CS1 = NULL;
case 3:
Serial.println("Charger is in BULK mode");
lcd.print("B");
CS1 = NULL;
case 4:
Serial.println("Charger is in ABSORB mode");
lcd.print("A");
CS1 = NULL;
case 5:
Serial.println("Charger is in FLOAT mode");
lcd.print("F");
CS1 = NULL;
case 9:
Serial.println("Charger is in INVERT mode");
lcd.print("I");
CS1 = NULL;
Serial.print("Charger State = ");
Serial.print("\n");
delay(3000);
Now the problem. I want to display some extra tags (H20, H21, H22, H23). For some reason those tags are getting corrupted shortly after booting up the Arduino. If I watch the receivedChars value I will see those tags show up ONCE right after boot up, then they are completely gone.
I think the problem is because those tags contain numerals in them. I think the "labelValue = atol(item);" is removing the tags, but I'm not %100 sure. I have been pulling my hair out for hours trying to determine the exact issue and how to fix it!
Any suggestions?
