It comes with a test code and a data sheet witch is downloadable here: www.wide.hk/download/65kOLEDdemo.rar
Im in doubt regarding the wiring. I though it would be pretty straight forward, but when I googled it, I found this description:
It seems my display is similar (maybe a knockoff -they are both called SSD1331) in the adafruit tutorial they are using a 3.3 V logic shifter? What is that, I why cant I just use the 3.3V pin on my Arduino Uno (or can I?)?
It takes a signal and converts it between 5V and 3V3 in either direction. It is just a couple of FETs on a board.
I why cant I just use the 3.3V pin on my Arduino Uno?
The 3V3 pin has only a 50mA current capacity. Also if you power that chip with 3V3 the outputs connecting to it from the arduino will still be 5V and thus damage the chip.
A lot of ebay auctions say "Arduino Compatible". In many cases that just means that an arduino and it can be hacked together in such a way that it works. In many cases that hacking is just a level shifter, or getting a 3.3v arduino.
You will need the (logic) level shifter otherwise you will most likely damage the display.
