I've been playing around with 595 shift registers and the wonderful tutorial about it. After some initial confusion (embarrassingly immortalized in this thread), I got it up and running very nicely.
I wanted to make sure I understood exactly what was going on, so I attached two momentary switches with pull-down resistors to two of the Arduino inputs, and set them up to send out a high or low bit, respectively, to the shift registers. It worked well, and I wanted to post the code in case any other beginners who are scared by all these clock pins might find it helpful.
/* This code uses the same wiring setup found in Carlyn Maw and Tom Igoe's excellent
ShiftOut Tutorial (http://www.arduino.cc/en/Tutorial/ShiftOut), with the addition of
two momentary switches with pull-down resistors on pins 2 and 3 (which could of course
be change). A tutorial explaining the wiring and code behind these switches can be found
in Limor "ladyada" Fried's tutorial lesson five (http://www.ladyada.net/learn/arduino/lesson5.html)
This code shifts a bit to the 595 register(s) each time a button is pressed (a 1 for one button,
and a 0 for the other) and displays the current state of the shift registers on LEDs. It can be
run with any number of 595s chained together without modification, except you might want to change the
defined number "daisy" if you want the initial LED blanking to work properly.
Writing this code convinced me that I more-or-less understood what was going on in the 595 tutorials.
I hope it's useful to others!
//Pin connected to ST_CP (storage, or latch clock) of 74HC595
#define latchPin 8
//Pin connected to SH_CP (shift clock) of 74HC595
#define clockPin 12
//Pin connected to DS (data input) of 74HC595
#define dataPin 11
//Pins connected to the two momentary switches
#define but1pin 2
#define but2pin 3
//Number of 595 chips daisy chained together (only important for blanking LEDs ininitially)
#define daisy 1
int but1state = 0;
int but2state = 0;
int but1val;
int but2val;
// Set the pins for controlling the 595(s)
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
// Write blank data to the LEDs to start out. Repeat for as many chips are chained together
digitalWrite(latchPin, LOW); // First, bring the latch pin low to allow data to be written
// Next, use the shiftOut function to write a 0 to each of the 595 chips.
// Changing the "0" to something else like B10101010 might be useful for debugging
for(int chipnumber = 0; chipnumber < daisy; ++chipnumber){
shiftOut(dataPin, clockPin, MSBFIRST, 0);
digitalWrite(latchPin, HIGH); // Bring the latch pin high again to display the data
// Set the pins for the buttons
pinMode(but1pin, INPUT);
pinMode(but2pin, INPUT);
// Initialize the momentary switch values
but1val = digitalRead(but1pin);
but2val = digitalRead(but2pin);
void loop(){
but1val = digitalRead(but1pin); // Check whether the button is pressed or not
delay(5); // This delay and the top if loop are to debounce the button
if(but1val == digitalRead(but1pin)){
/* This next if loop checks if the button state has changed, and if the button is currently
pressed. If you wanted the event to occur when the button was released, or if you're using a
pull-up resistor instead of a pull-down, you should change the "HIGH" to "LOW" here. */
if(but1state != but1val && but1val == HIGH){
digitalWrite(latchPin, LOW); // First, set the latch low to allow new data to be written
digitalWrite(clockPin, LOW); // Next, set the clock pin low to tell the chip to start listening
digitalWrite(dataPin, HIGH); // Set the data bit high to write out a high bit to the register
digitalWrite(clockPin, HIGH); // Set the clock high to save the high data bit
digitalWrite(latchPin, HIGH); // Finally, set the latch high to display the new contents of the register
digitalWrite(dataPin, 0); // Just to keep to data path clear
but1state = but1val;
// This is exactly the same as above, or it's for button two, and we set the data bit low instead of high
delay(5);
if(but2val == digitalRead(but2pin)){
if(but2state != but2val && but2val == HIGH){
digitalWrite(dataPin, LOW); //This should already be low, so it's sort of redundant. It's here for clarity
but2state = but2val;
(Edit: fixed the links)
