SPI Address?
Hello,
i am currently working with the ILI9341 touchscreen Display and have no idea where to read and wite using the SPI communication protocol.
The following is a link to the datasheet of the Touch controller.
  1. Can you please, tell me where to read the X, Y coordinates? Should i use the SPI.transfer() to send a byte following what on table 6 and 7?
  2. Moreover, am i right that the datasheet specifies that the touch controller's output is a 12 bit word like mentioned on Page 3, but also 8 bit like mentioned in Table 7?
  3. The SPI Settings: What settings shoud i use for the speed? Page 3 suggest 125kHz, but wikipedia mentioned that SPI displays are "in MB" fast.
P.S: I only had Introduction to Mechatronic and i am familiar with the basic of electrotechnic. I would like to apologize for my lack of understanding.
Thanks
  1. The SPI Settings: What settings shoud i use for the speed? Page 3 suggest 125kHz, but wikipedia mentioned that SPI displays are "in MB" fast.
The 125KHz is not the SPI speed but is the speed of the A/D conversion. The data sheet says it will work at any SPI frequency that is 2MHz or lower.
Basically yes, you send bytes and get them back with SPI. Note that when you send a byte with SPI.transfer() it returns the results of the last command you sent. From figure 24 it looks like there should be three bytes in the transfer.
I have not used this device so I can't give you chapter and verse on the code you need.
Despite the title the SPI bus does not use addresses.
  1. Moreover, am i right that the datasheet specifies that the touch controller's output is a 12 bit word like mentioned on Page 3, but also 8 bit like mentioned in Table 7?
Yes the output can be specified to be either 12 bits or 8 bits. Which it is is specified by bit 3 in the controller byte.
