Hello everybody,
I am currently working on a robotics project for a university. I am using two Arduino boards that are communicating via SPI. The robot has to perform a variety of tasks and I decided to split up the tasks; the robotic arm will be operated by the master Arduino board and the sensors will be operated by the slave Arduino board. As such, I need the two Arduino boards to communicate in both directions.
I have searched topics about SPI on this forum and I found this great website:
I decided to model my code on the SPI bi-directional example (title example is called How to get a response from a slave) in that website. However, I have some questions on exactly how to implement the code. My questions are with regards to the SPI interrupt functions and the code in the loop function of the master code.
I have attached the entire code from the website for both the master and slave and the results. My first question is with regards to this section of master code executed in the loop function:
// enable Slave Select
digitalWrite(SS, LOW);
transferAndWait ('a'); // add command
transferAndWait (10);
a = transferAndWait (17);
b = transferAndWait (33);
c = transferAndWait (42);
d = transferAndWait (0);
// disable Slave Select
digitalWrite(SS, HIGH);
In addition, here is the SPI function used in the master code:
byte transferAndWait (const byte what)
byte a = SPI.transfer (what);
delayMicroseconds (20);
return a;
} // end of transferAndWait
In order to receive data from the slave, the master has to send data first. But what I want to do on my code is for the master to send a SPI command to the the slave, the slave starts the sensors, collects data, and then send the results to the master. My sensor code will be executed in the loop function. Is it possible for me to execute code in the loop function of the slave and then uses SPI to send the results back to the master?
Here is the interrupt code used by the slave:
// SPI interrupt routine
ISR (SPI_STC_vect)
byte c = SPDR;
switch (command)
// no command? then this is the command
case 0:
command = c;
SPDR = 0;
// add to incoming byte, return result
case 'a':
SPDR = c + 15; // add 15
// subtract from incoming byte, return result
case 's':
SPDR = c - 8; // subtract 8
} // end of switch
} // end of interrupt service routine (ISR) SPI_STC_vect
Do I have to execute my slave sensor code within that interrupt on the slave? Or is it possible to easily execute the sensor code in the loop?
Someone might ask as to why don't I just one Arduino Mega board. The reason why is because the slave board will be doing a lot more than just sensor code by the time this project is done. A lot of hardware will be connected to both boards and I decided that two boards working together is better than jamming all the hardware into one mega board. In addition, one mega does not have available all the hard interrupts that I need. I need to use two boards.
Thanks everyone for reading and your time,
David
SPI master.txt (1.62 KB)
SPI output results.txt (136 Bytes)
SPI slave.txt (972 Bytes)
