SPI bus returns -1
I have a series of LS7366 SPI devices daisy chained to an arduino mega. The schematic is very similar to this breakout board:
I tried the code from this project as a baseline after attaching a motor and encoder to one of the 5 available spots.
However, I always get a -1 return value. What would cause a -1 return?
The baseline code I copied (and modified sightly to get a steady PWM) is below:
/=========================HEADER=============================================================
   Dual LS7366 Quadrature Counter Test Code
   AUTHOR: Jason Traud
   DATE: June 22, 2013
   This is a simple test program to read encoder counts
   collected by the LS7366 breakout board. The counts are
   then displayed in the Arduino's serial monitor at a
   baud rate of 9600
   Hardware: Arduino Uno R3
   Powered
   LS7366 Breakout    -------------   Arduino
            MOSI   -------------------   SDO (D11)
            MISO   -------------------   SDI (D12)
            SCK    -------------------   SCK (D13)
            SS1    -------------------   SS1 (D7)
            SS2    -------------------   SS2 (D8)
            GND    -------------------   GND
            VDD    -------------------   VCC (5.0V)
   License: CCAv3.0 Attribution-ShareAlike (http://creativecommons.org/licenses/by-sa/3.0/)
   You're free to use this code for any venture. Attribution is greatly appreciated.
// Inclde the standard Arduino SPI Library, please ensure the SPI pins are
// connected properly for your Arduino version
#include <SPI.h>
// Slave Select pins for encoders 1 and 2
// Feel free to reallocate these pins to best suit your circuit
const int slaveSelectEnc1 = 48;
const int slaveSelectEnc2 = 46;
// These hold the current encoder count.
signed long encoder1count = 0;
signed long encoder2count = 0;
const int Motor_PWM6 = 5;      //Re-name later corresponding to motor relative to rover
const int DIR_PWM6 = 40;
void initEncoders() {
  // Set slave selects as outputs
  pinMode(slaveSelectEnc1, OUTPUT);
  pinMode(slaveSelectEnc2, OUTPUT);
  // Raise select pins
  // Communication begins when you drop the individual select signsl
  digitalWrite(slaveSelectEnc1,HIGH);
  digitalWrite(slaveSelectEnc2,HIGH);
  SPI.begin();
  // Initialize encoder 1
  //    Clock division factor: 0
  //    Negative index input
  //    free-running count mode
  //    x4 quatrature count mode (four counts per quadrature cycle)
  // NOTE: For more information on commands, see datasheet
  digitalWrite(slaveSelectEnc1,LOW);        // Begin SPI conversation
  SPI.transfer(0x88);                       // Write to MDR0
  SPI.transfer(0x03);                       // Configure to 4 byte mode
  digitalWrite(slaveSelectEnc1,HIGH);       // Terminate SPI conversation
  // Initialize encoder 2
  digitalWrite(slaveSelectEnc2,LOW);        // Begin SPI conversation
  digitalWrite(slaveSelectEnc2,HIGH);       // Terminate SPI conversation
long readEncoder(int encoder) {
  // Initialize temporary variables for SPI read
  unsigned int count_1, count_2, count_3, count_4;
  long count_value;
  // Read encoder 1
  if (encoder == 1) {
    SPI.transfer(0x60);                     // Request count
    count_1 = SPI.transfer(0x00);           // Read highest order byte
    count_2 = SPI.transfer(0x00);
    count_3 = SPI.transfer(0x00);
    count_4 = SPI.transfer(0x00);           // Read lowest order byte
  // Read encoder 2
  else if (encoder == 2) {
  // Calculate encoder count
  count_value = (count_1 << 8) + count_2;
  count_value = (count_value << 8) + count_3;
  count_value = (count_value << 8) + count_4;
  return count_value;
void clearEncoderCount() {
  // Set encoder1's data register to 0
  // Write to DTR
  SPI.transfer(0x98);
  // Load data
  SPI.transfer(0x00);  // Highest order byte
  SPI.transfer(0x00);
  SPI.transfer(0x00);
  SPI.transfer(0x00);  // lowest order byte
  delayMicroseconds(100);  // provides some breathing room between SPI conversations
  // Set encoder1's current data register to center
  SPI.transfer(0xE0);
  // Set encoder2's data register to 0
  // Write to DTR
  SPI.transfer(0x98);
  // Load data
  SPI.transfer(0x00);
  SPI.transfer(0x00);
  // Set encoder2's current data register to center
  SPI.transfer(0xE0);
 Serial.begin(9600);      // Serial com for data output
 initEncoders();       Serial.println("Encoders Initialized...");
 clearEncoderCount();  Serial.println("Encoders Cleared...");
 pinMode(DIR_PWM6, OUTPUT);
  pinMode(Motor_PWM6, OUTPUT);
  //Corresponds to SSPin2-Read Encoder 2
  digitalWrite(DIR_PWM6, LOW);
  analogWrite(Motor_PWM6, 100);
 // Retrieve current encoder counters
 encoder1count = readEncoder(1);
 encoder2count = readEncoder(2);
 Serial.print("Enc1: "); Serial.print(encoder1count); Serial.print(" Enc2: "); Serial.println(encoder2count);
"No data" would give you -1 because the data bus would stay high (all 1 bits).
