I am using a simplified version of Nick Gammon's SPI Tutorial. Specifically, I am using code from the section "How to get a response from a slave".
In this section, the SPI Master sends a number to the SPI Slave which adds a number to it and returns it to the Master. Ultimately what I'd like to do is use the slave to return a sensor reading back to the master.
For the sensor in my project, I'm using the Adafruit SHT31 sensor with the Adafruit SHT31 library. When I try each component of my slave code separately - the SPI Master/Slave communication and the sensor reading, they work okay. However, when I try to run both sections of the code together, the Master/Slave communication occasionally gets "out of sync".
In my code example, without the sensor code running, if the Master sends a "5", the Slave adds "2" and returns a "7". However, if I include the " tempSensor(); " function call, the Slave occasionally returns not the "7", but the same number the Master sent to the Slave, in my example, it returns a "5". Somehow, running the sensor part of the code causes the SPI communications to get out of sync.
My code example below shows a section of the Slave code
Thanks for any suggestions
void loop (void)
//-------------Get Temperature-----------
tempSensor(); //Call function to measure temperature
if (process_it) //if byte has arrived from MASTER
Serial.println(inByte, DEC);
SPDR = inByte +2; //add 2 to byte from MASTER & put it in SLAVE Data Register
// to be read by MASTER at next SPI.Transfer from MASTER
process_it = false;
} // end of loop
//--------------------------------FUNCTIONS----------------------------
// SPI interrupt routine
ISR (SPI_STC_vect)
inByte = SPDR; // read byte received from Master in Slave SPI Data Register (SPDR)
process_it = true;
} // end of interrupt service routine (ISR) SPI_STC_vect
//------------Read Temperature and Humdity Sensor--------------------
void tempSensor()
float t = sht31.readTemperature();
if (! isnan(t)) { // check if 'is not a number'
Serial.print("Temp *C = "); Serial.println(t);
Serial.println("Failed to read temperature");
