SPI Communication between ATMEGA 324PB and Arduino Nano
Hello,
Here I'm trying to Send the SPI command from the master (Arduino Nano) to the slave(ATMEGA324PB).
First Master receives a command from the serial monitor. When the serial message receives completely, the Master passes the message to the Slave. Whenever the slave has a message to send, it will interrupt the Arduino nano using pin 3. However, in the first round slave send messages to master, and master can read it successfully. But in the second round It couldn't happen. I was unable to find the issue. I will attach the codes below.
User message is like in this manner XF01600#.
  1. Send X (or Y)
  2. Send F (or B)
  3. Send 01600
  4. Send #
This is my Master Code :
` #include <SPI.h>`
 char Direction;
char Axis;
char TxCommand;
char TxEnd;
bool stringComplete = false;  // Is receive complete ?
bool TxComplete=false;
int k=0;
int j=0;
String StepCount;
SPISettings setting(200000,MSBFIRST,SPI_MODE0);
  pinMode(10,OUTPUT);
  pinMode(9,OUTPUT);
  pinMode(2,OUTPUT);
  attachInterrupt(digitalPinToInterrupt(3),SlaveReceive,RISING);
  SPI.begin();
void SlaveReceive(){
  SPI.begin();
  SPI.beginTransaction(setting);
  digitalWrite(10,LOW);
  TxCommand=SPI.transfer(0xFF);//dummy
  TxEnd=SPI.transfer(0xFF);//dummy
  digitalWrite(10,HIGH);
  SPI.endTransaction();
  Serial.print("Received Command-");
  Serial.println(TxCommand  );
  Serial.print("Received End-");
  Serial.println(TxEnd);
  if(TxEnd=='~'){
    TxComplete=true;
void SPI_Transfer(){
  SPI.transfer(Direction);//transfer direction
  delay(5);
  SPI.transfer(StepCount.length());//transfer incoming step length
  delay(5);
  for(int i=0;i<StepCount.length();i++){//transfer step count;
      SPI.transfer(StepCount[i]);
      Serial.println(StepCount[i]);
      delay(5);
    SPI.transfer('#');
  delay(5);
  if (stringComplete) {
    if(Direction=='F'){
        digitalWrite(2,HIGH);
    else if(Direction=='B'){
        digitalWrite(2,LOW);
     Serial.print("Direction-");
     Serial.println(Direction);
     Serial.println(StepCount);
     Serial.println(StepCount.length());
    if(Axis=='X'){ // Chip Select line for X axis driver is pin 10;
      SPI_Transfer();
    else if(Axis=='Y'){ /// Chip select line for Y axis driver is pin 9;
      digitalWrite(9,LOW);
      SPI_Transfer();
      digitalWrite(9,HIGH);
    k=0;
  if(TxComplete){
    if(TxCommand=='S'){
      TxComplete=false;
void serialEvent() {
  while (Serial.available()>0) {
    if(k==0){
        Axis = Serial.read();
        k++;
    else if(k==1){
        Direction=Serial.read();
        k++;
    else if(Serial.read()!='#'){
      //StepCount[k-1]=Serial.readString();
      StepCount=Serial.parseInt();
      k++;
    else{
      stringComplete = true;
Slave Main Command :
while(1){
		if(SPI_RECEIVE_COMPLETE){
			SPI_RECEIVE_COMPLETE=false;
			PORTA |=(1<<4);
			Decode_SPI_Command();
			switch (SPI_Command)
				case 'F':
					_Run_Motor(SPI_Data, true, 1, 0.3);//10 CYCLE
					SlaveSendData(0x53);//S
				case 'B':
				    _Run_Motor(SPI_Data, false, 1, 0.3);
			for(uint8_t i=0;i<15;i++){
				SPI_Received_Data[i]=0;
			SPI_Data=0;
			SPI_BYTES_Transfer=0;
		PORTA &=~(1<<4);
The Slave data send function :
void SlaveSendData(uint8_t SlaveCommand){
	SPI_Data_TX=true;
	SPDR1=SlaveCommand;
	SPI_Transmit_Data[0]=0x7E;//~
	PORTA |=(1<<3);
	_delay_ms(10);
	PORTA &=~(1<<3);
Slave SPI interrupt function :
ISR(SPI1_STC_vect){
	if(SPI_Data_TX){//slave is transmitting data
		SPDR1 = SPI_Transmit_Data[SPI_BYTES_Transfer];
		SPI_BYTES_Transfer++;
		if(SPI_Received_Data[SPI_BYTES_Transfer-1]=='~'){
			SPI_Data_TX=false;
			//SPDR1=0x00;
	else{
		SPI_Received_Data[SPI_BYTES_Transfer] = SPDR1;
		if(SPI_Received_Data[SPI_BYTES_Transfer-1]=='#'){
			SPI_RECEIVE_COMPLETE=true;
			SPDR1=0x00;
Here I have found that in the else part SPI_RECEIVE_COMPLETE=true; never occurs in the second try. But I couldn't find where the issue is..?
serial monitor
Could you please take a look, Thank you.
Sorry I cannot read the pictures. It sounds like you are not properly keeping the master/slave relationship correct. Only a master can control the SPI clock. It has to clock the data out of the slave. You can turn the slave to master mode and the master to slave mode to return messages but that can get confusing. SPI is bidirectional, you receive while sending. You have to send something to receive something. Hopefully this helps.
In your slavereceive() after spi.begin call spi.usinginterrupt(pin) to disable and then reenable interupt before and after begin and end.
Didnt look any further but as per arduino reference if u call spi in interrupt you have to call usinginterrupt method not to get into conflicts. it may not solve your current issue tho.
Agreed with above post its hard to read pictures especially on the phone.
Hi gilshultz, Sorry for the mistake, I will update now. Thank you for your reply.
Hi surepic, thank you for your support and I will update the codes again
