SPI communication between esp nodemcu with arduino uno
I am new to arduino serial pheripheral interface ,i want to send data to nodemcu from arduino uno …
i downloded code from internet for testing purpose but it unclear and find some error in declaration ,as per my view these is just simple code but dont know why it get error…
so please guide to solve these problem…
arduino uno work as slave device while node mcu master device.code are like that…
[nodemcu master code]
#include<SPI.h>
char buff=“Hello Slave\n”;
Serial.begin(9600); /* begin serial with 9600 baud /
SPI.begin(); /
begin SPI */
for(inti=0; i<sizeof buff; i++) /* transfer buff data per second /
SPI.transfer(buff
delay(1000); *
[arduino uno slave code ]
#include <SPI.h>
char buff [100];
volatile byte index;
_volatile bool receivedone; /
use reception complete flag */_
void setup (void)
  • Serial.begin (9600);*
    _ SPCR |= bit(SPE); /* Enable SPI /_
    _ pinMode(MISO, OUTPUT); /
    Make MISO pin as OUTPUT */_
  • index = 0;*
  • receivedone = false;*
    _ SPI.attachInterrupt(); /* Attach SPI interrupt /_
    void loop (void)
    _ if (receivedone) /
    Check and print received buffer if any */_
  • buff[index] = 0;*
  • Serial.println(buff);*
  • index = 0;*
    // SPI interrupt routine
    ISR (SPI_STC_vect)
  • uint8_t oldsrg = SREG;*
  • cli();*
  • char c = SPDR;*
  • if (index <sizeof buff)*
  • buff [index++] = c;*
    _ if (c == ‘\n’){ /* Check for newline character as end of msg */_
  • receivedone = true;*
  • SREG = oldsrg;*
you want the Uno to be the slave?
The NodeMCU is 3V3 device while the UNO runs at 5V. Did you use a level converter between them? Otherwise you might have already fried the ESP.
