Hi ... I would like to sent some data from one Arduino (Master) to the second Arduino (Slave). I made a simple program, to transfer the time - how long I was holding a button.
This is the code for Master :
long int time=0;
boolean JE=false;
pinMode(2, INPUT); // declare pushbutton as input digital pin 2
//setting the SPI - the same like in the datasheet for 328
DDRB=(1<<DDB3)|(1<<DDB5);
SPCR=(1<<SPE)|(1<<MSTR)|(1<<SPR0);
void loop(){
//checking&counting the time while button is pressed
if (digitalRead(2)==HIGH)
time=millis();
JE=true;
while (digitalRead(2)==HIGH) {}
if (JE)
JE=false;
//sending the result through SPI
SPDR=(millis()-time)/100;
while(!(SPSR & (1<<SPIF)));
This is the code for the Slave :
void setup(){
//setting the SPI communication to Slave - like in the datasheet fro 328
DDRB=(1<<DDB4);
SPCR=(1<<SPE);
void loop(){
int val;val=slave();
Serial.print(val);
Serial.print(" - ");
Serial.print(val,BIN);
Serial.println(val,DEC);
int slave(){
return SPDR;
Please ... could you tell me what am I missing ??? I'm using digital pin 13, 12, 11,10 for the SPI communication. I have tried this connections :
M13-S13 M13-S13
M12-S12 ... or ... M12-S11
M11-S11 M11-S12
M10-S10 M10-S10
But without any results. thank you for any advice / correction in my codes.
Zholy
