SPI communication bus
I would like to know how many slaves (max) can I connect to SPI bus?
How far can I connect between master and slave for SPI bus?
Thanks.
Theoretically as many as you have free pins for the CS signal. But in reality you get to long cabling with more than about half a dozen devices.
That depends on the speed you drive the SPI bus with. For low speeds (< 1MHz) half a meter should work well if there is not to much electrical noise in the environment. The higher the clock frequency the shorter the bus length should be.
Thanks
