SPI communication question
I seen examples in Internet about SPI communication but they are not enough.
I have Arduino uno connected to ESP 8266 thru SPI.
I want Arduino uno SPI master to both send and receive data.
And I want ESP 8266 SPI slave to both send and receive data.
Can you give me a code example of this?
Can you afford to operate ESP8266 as SPI-Master and UNO as SPI-Slave?
No idea of the procedures of initializing ESP8266 as SPI-Slave.
Yes you are correct.
Maybe only ESP8226 can send data…
Maybe I will not use SPI then I will use RX - TX as serial, I will add a switch (ON/OFF) to disconnect them if I upload my code.
You don't need to add a switch, that's what the programmer does with the reset pin.
mikechale:
Maybe only ESP8226 can send data...
You may use software serial ports (SUART) for both ESP8266 and UNO in order to keep the (hardware) UART Ports remain connected wit their respective IDE/SM for uploading/debugging sketches.
