Thank you for your response. I have changed the code. I still have the same problem.
I always get the same exact value. I have checked my connections over and over. If nothing is wrong with this code, I am going to assume that the chip I am using is damaged!
Here's the modified code: #include <SPI.h>
long result;
unsigned int byte2;
unsigned int byte3;
unsigned int byte4;
const int chipSelectPin = 10;
digitalWrite(chipSelectPin, LOW);
// Sending 4 bytes as a command
SPI.transfer(0x20);
SPI.transfer(0x00);
SPI.transfer(0x00);
SPI.transfer(0x00);
delay(4);
result = SPI.transfer(0x00);
Serial.print("First byte: ");
Serial.println(result,BIN);
result = result << 24; // shift the first byte all the way to the left
byte2=SPI.transfer(0x00)<<16;
Serial.print("Second byte: ");
Serial.println(byte2,BIN);
result |=(byte2);
byte3=SPI.transfer(0x00)<<8;
Serial.print("Third byte: ");
Serial.println(byte3,BIN);
result |=(byte3);
byte4=SPI.transfer(0x00);
Serial.print("4rth byte: ");
Serial.println(byte4,BIN);
result |=(byte4);
digitalWrite(chipSelectPin, HIGH);
maan:
First byte: 1111111
Second byte: 0
Third byte: 1111111100000000
4rth byte: 11111111
1111111000000001111111111111111
It's impossible for the third byte to contain 16 bits so perhaps you should try again.
Try replacing this code:
SPI.transfer(0x20);
SPI.transfer(0x00);
SPI.transfer(0x00);
SPI.transfer(0x00);
delay(4);
result |=(byte2);
result |=(byte3);
result |=(byte4);
with this:
SPI.transfer(0x20);
SPI.transfer(0x00);
SPI.transfer(0x00);
SPI.transfer(0x00);
digitalWrite(chipSelectPin, HIGH); // End of command
delay(4);
digitalWrite(chipSelectPin, LOW); // Start of data retrieval
Serial.print("One byte: ");
Serial.println(result,HEX);
result = result << 8 | SPI.transfer(0x00);
Serial.print("Two bytes: ");
Serial.print("Three bytes: ");
Serial.print("Four bytes: ");
Any more tips on this device? I am having a hard time reading the data. It should be easy, but so far it isn't.
// the sensor communicates using SPI, so include the library:
#include <SPI.h>
long result;
const int chipSelectPin = 7;
// start the SPI library:
SPI.begin();
pinMode(7, OUTPUT);
digitalWrite(7,HIGH);
SPI.setBitOrder(MSBFIRST);
SPI.setClockDivider(SPI_CLOCK_DIV32);
SPI.setDataMode(SPI_MODE3);
delay(100);
digitalWrite(7, LOW);
SPI.transfer(0x20);
SPI.transfer(0x00);
SPI.transfer(0x00);
SPI.transfer(0x00);
digitalWrite(7, HIGH); // End of command
delay(4);
digitalWrite(7, LOW); // Start of data retrieval
Serial.println(result);
delay(100);
Currently, the only output is; 1006895115, no matter how I move the device.
SPI.transfer(0x20);
SPI.transfer(0x00);
SPI.transfer(0x00);
SPI.transfer(0x00);
delay(4);
delay(100);
I'm sorry I failed to mention it before but it would be highly unusual for the Slave Select pin (7) to be set HIGH between the sending of the command and the receiving of the data. Try removing the three indented lines.
Thanks for your reply. I removed the lines and had no succes. The output is -1 now, that's it. Stupid thing is, I have a (cheap ebay salae clone) logic analyser laying around in the house, but I cannot find it. I did find 'the missing roll of solder' though.
SuperR:
I was wrong. I just looked at the datasheet again and your previous code was right. As you send out Command-N you receive the results from the previous command (N-1). The command and response are two different transactions.
It might be time to give up on the ADXRS450 and get a easier to use gyroscope.
I asked the device nicely, and it works now. I did not change much, set the clock polarity and phase to 0 and used an extra integer to store the lowest 6 bits from the data. That´s it. Data looks good.
#include <SPI.h>
int result;
int result2;
int Gyro1;
SPI.begin();
pinMode(7, OUTPUT);
SPI.setClockDivider(SPI_CLOCK_DIV16);
SPI.setDataMode(SPI_MODE0);
delay(100);
result = SPI.transfer(0x20);
result2 = SPI.transfer(0x00) >>2;
SPI.transfer(0x00);
result = result << 6 | result2;
Gyro1 = (Gyro1)*0.5 + result*(1 - 0.5);
Serial.println(Gyro1);
