SPI communication with DRV8711 BoosterPack Board
Hi all,
I have recently bought TI’s DRV8711 BoosterPack Board http://www.ti.com/tool/boost-drv8711.
I am new to Arduino SPI coding. So I am using the default SPI library.
Here is my code just to read the torque register.
#include <SPI.h>
#  define CSpin    4
#  define STEPpin  5
#  define DIRpin   6
#  define RESETpin 7
  pinMode(CSpin,OUTPUT);
  SPI.beginTransaction(SPISettings(1000000, LSBFIRST, SPI_MODE0));
  SPI.begin();
  Serial.print("SPCR: ");
  Serial.println(SPCR,BIN);
  digitalWrite(CSpin,HIGH);
  SPI.transfer(0x9);//selecting torque register to read
  int data=SPI.transfer(0x00);
  Serial.print("Torque register: ");
  Serial.println(0x9,BIN);
  Serial.print("Torque register return value: ");
  Serial.println(data,BIN);
I feel the TORQUE register is returning wrong value.
Also When I checked the SPCR register, the MSTR bit is LOW.
I am not able to figure it out why my Arduino is not in Master mode?
KIndly guide me. I have been trying to understand since two days.
Board?
Arduino Uno. :)
Pin 10 is the hardware Slave Select not pin 4. You can use pin 4 for your particle device but pin 10 has to be an output. The documentation has more details...
http://www.arduino.cc/en/reference/SPI
Is HIGH slave select for your device?
Yes High is for Slave select. I have corrected the CSpin to PIN 10, But still On reading the SPCR register, I am not able to see the MSTR bit high.
#include <SPI.h>
#  define CSpin    10
#  define STEPpin  5
#  define DIRpin   6
#  define RESETpin 7
  SPI.begin();
I have been trying the other way by using the DRV8711 library took from here.
I have used the flow of programming into mine.
But now the problem is : I am getting the register value as 1111111111111111.
Whereas by using the library above, the code returns perfect values.
Where did I mess??
Here are the files of my learning project.
DRIVER_8711.ino (499 Bytes)
drv8711.h (3.36 KB)
DRVextn.ino (2.03 KB)
