Good Day,
I am having some trouble talking to an optical sensor array with SPI (MLX75306, data sheet at: https://www.melexis.com/-/media/files/documents/datasheets/mlx75306-datasheet-melexis.pdf). I am using an Arduino Nano Every. I am not familiar with SPI communication and I have the feeling I am missing something essential in the communication protocol. I attached an interrupt to the frameready pin of the optical array, but this interrupt never gets triggered. From what I understand from the datasheet, sending the “Start Integration” command should result in Frameready going high after a set time. I have got my Arrduino connected to the MLX75306 as follows:
Arduino —> MLX75306:
D12/MISO → MISO
D11/MOSI → MOSI
D13 → SCLK
D6 → Frameready
D5 → CS
+3V3 → pin 5 & 6 (3v3)
GND → pin 4 (GND)
with a 1muF and .1muF in parallel between pin 4 and pin 5 on the MLC75306.
This is the arduino code (I am not doing a detailed read out of the sensor yet, this code is mainly to get the interrupt to trigger):
#include <SPI.h>
const int dataReadyPin = 6;
const int chipSelectPin = 5;
const byte MLX75306_CR = 0b11110000; // chip reset
const byte MLX75306_SI = 0b10111000; // start integration
const byte MLX75306_RO8 = 0b10011001; //Read 8bit
const byte MLX75306_SM = 0b11000110; // Sleep Mode
const byte MLX75306_WU = 0b11000011; // Wake UP
const byte TIME_INT_MSB = 0b01001110; // MSB+LSB is one 16 bit byte
const byte TIME_INT_LSB = 0b00100100; //current value 20000, for 10 ms integration time
int i = 0;
SPI.begin();
pinMode(dataReadyPin, INPUT);
pinMode(chipSelectPin, OUTPUT);
initiate();
start();
sleep();
attachInterrupt(digitalPinToInterrupt(dataReadyPin), ReadData, RISING);
byte inByte = 0;
initiate();
start();
acquire_8b();
Serial.println("Sent");
delay(2000);
void initiate()
SPI.beginTransaction(SPISettings(2000000, MSBFIRST, SPI_MODE3));
digitalWrite (chipSelectPin, LOW);
SPI.transfer(MLX75306_CR);
SPI.transfer(0x00);
SPI.transfer(0x00);
digitalWrite (chipSelectPin, HIGH);
SPI.endTransaction();
void start()
SPI.transfer(MLX75306_WU);
SPI.transfer(0x00);
SPI.transfer(0x00);
void sleep()
SPI.transfer(MLX75306_SM);
SPI.transfer(0x00);
SPI.transfer(0x00);
void acquire_8b()
SPI.transfer(MLX75306_SI);
SPI.transfer(TIME_INT_MSB);
SPI.transfer(TIME_INT_LSB);
void ReadData()
byte inByte;
SPI.transfer(MLX75306_RO8);
SPI.transfer(0x02);
SPI.transfer(0x8F);
inByte = SPI.transfer(0x00);
Serial.println(inByte, BIN);
Many thanks!
