SPI Connection Between Arduino ATMEGA 2560& ESP8266-ESP12 Not Working
can Someday Provide Me A Good Link or Demo Code On How to connect and esp and mega to transmit 84 byte test. Ihave Written 10 codes but none of works anda always leads to wdt(Soft Reset) or garbage data
Master
#include<SPI.h>
int swi=0;
  digitalWrite(SS,HIGH);
  SPI.begin();
  char c;
  digitalWrite(SS,LOW);
  if(swi==0)
     for(const char *p="Hello, World!\n";c=*p;p++)
     SPI.transfer(c);
     for(const char *p="Bye Bye !, World!\n";c=*p;p++)
     SPI.transfer(c);
  swi=1-swi;
Slave
#include<SPI.h>
char buf[100];
volatile byte pos;
volatile boolean process_it;
 pinMode(MISO,OUTPUT);
 SPCR|=_BV(SPE);
 pos=0;
 process_it=false;
 SPI.attachInterrupt();
ISR(SPI_STC_vect)
     byte c=SPDR;
     if(pos<sizeof buf)
        buf[pos++]=c;
        if(c=='\n')
            process_it=true;
 if(process_it)
    buf[pos]=0;
    Serial.println(buf);
    pos=0;
    process_it=false;
shared none of them. If you want help with your code, post it.
If you want someone to write the code for you, head over to Gigs and Collaboration, and get your wallet out (AND define some real requirements!).
Here is the code problem is that slave is not recieving or is recieving garbage data; ESP8266 Master ATMEGA328 Slave Wiring Is Ok Checked It
Okgot it work can i post back in this thread only if need further help ??
Sorry for bothering again can you look at this code and tell me what wrong i am unable to match the send & the received data and for some reason the data recieved is being printed in new line;
#include<SPI.h>
int swi=0;
char buf[100];
int pos=0;
char *DataOut="Hello World , Bye Bye World !\n";
String DataIn="";
  SPI.begin();
  SPI.setClockDivider(SPI_CLOCK_DIV8);
  String Vector1(DataOut);
  SendToDev(DataOut);
  NormalizeData(Vector1);
  NormalizeData(DataIn);
  if(Vector1.equals(DataIn)>=0)
    Serial.print("Data Send OK : ");
    Serial.println(DataIn);
      Serial.print("Error MisMatch Data Sent : ");
  delay(5);
void NormalizeData(String S)
  S.replace("\n","");
  S.replace("\r","");
  S.replace("\0","");
void SendToDev(char *P)
  DataIn="";
  char C;byte R;
  for(const char *S=P;C=*S;S++)
         R=SPI.transfer(C);
         C=R;
         DataIn.concat(C);
You also seem completely unable to show what you are seeing. Without seeing what you do, there isn’t a hope in hell of helping you.
         C=R;
Why are you storing the return value from the SPI transfer in a byte? Why are you then overwriting C?
C=R is to capture the return message
and storing in byte to make it common on both sides so no confusion occurs
but i completed the code which worked fine for some time and then just for some reason decided to breakup
here is the code
Master Code :
#include<SPI.h>
int swi=0;
char buf[100];
int pos=0;
char *DataOut="Hello World !\n";
String DataIn="";int Retry=0;
  SPI.begin();
  long int time = millis(); int Time=0;
  while(time+5000>millis())
  SendToDev(DataOut);
  if((Vector1.indexOf(DataIn)>=0)&&(!DataIn.equals("")))
      Serial.print("Error MisMatch Echo Data : ");
      Serial.println("Origin Data : "+Vector1);
    Time=ValidDev();
  if(Time==0)
    Serial.print("OOPS SomeThing Went Wrong Retrying...");
    Serial.println(Retry);
    Retry++;
    Serial.print("Waiting For Processing To Complete....");
    Serial.println(Time);
    delay(Time+10);
    time = millis();
    Retry=0;
    GetDev("FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF");
    Serial.print("Processed : ");
    delay(5);
  Serial.print("Sorry Something Broke Trying 2 Fix.....");
  S.replace("\n","");
  S.replace("\r","");
  S.replace("\0","");
  DataIn="";
  char C;byte R;
         R=SPI.transfer(C);
         C=R;
         DataIn.concat(C);
  DataIn=DataIn.substring(1);
int ValidDev()
   byte R;int T;
   R=SPI.transfer('F');
   T=R;
   Serial.println(T);
   return T;
void GetDev(char *P)
  DataIn="";
  char C;byte R;
  while((pos<255)&&(C!='\n'))
         R=SPI.transfer(C);
         C=R;
         DataIn.concat(C);
         if(C=='\n')
         pos++;
  pos=0;
Slave Code :
#include<SPI.h>
char buf[100];
volatile byte pos;
String DataIn;
volatile int waitime=75,stage=0;
char P[]="0000Data Processed \n\n\n";
 SPCR|=_BV(SPE);
 pos=0;
 process_it=false;
ISR(SPI_STC_vect)
   byte C=SPDR;
   if(stage==0)
       SPDR=C;
     if(pos<sizeof buf)
        buf[pos++]=C;
        if(C=='\n')
            process_it=true;
            stage=1;
    else if(stage==1)
      SPDR=(byte)waitime;
      pos=0;
      stage=2;
    else if(stage==2)
         if(P[pos]=='\n')
            stage=0;
            pos=0;
            SPDR=P[pos];
            pos++;
 Serial.print(stage);
 Serial.print("Value Of Pos");
 Serial.println(pos);
 if(process_it)
    buf[pos]=0;
    DataIn.concat(buf);
    if(strcmp(buf,"Hello World !"))
     // Serial.println("Command OK ");
    pos=0;
    process_it=false;
    DataIn="";
For some reason code broke after few runs and now for some reason pos value seems to gotten stuck at 100.
My goal is to retrieve text string as output after waiting for specific time length of string / char may vary from 84-164 bytes
Hardware Used Are ESP8266-ESP12 And Atmega328
i m attaching the output screenshot it looks like synchronization issue
can you run the code and confirm if thats ok
Master Code
#include<SPI.h>
int swi=0;
char buf[100];
int pos=0;
  SPI.begin();
  SendToDev(DataOut);
    Time=ValidDev();
  if(Time==0)
    Retry++;
    delay(Time+10);
    time = millis();
    Retry=0;
  S.replace("\n","");
  S.replace("\r","");
  S.replace("\0","");
  DataIn="";
  char C;byte R;
         R=SPI.transfer(C);
         C=R;
         DataIn.concat(C);
int ValidDev()
   byte R;int T;
   T=R;
   Serial.println(T);
   return T;
  DataIn="";
  char C;byte R;
  while(pos<255)
         R=SPI.transfer(C);
         C=R;
         DataIn.concat(C);
         if(C=='\n')
         pos++;
         delayMicroseconds(55); //added for test
  pos=0;
Slave Code
#include<SPI.h>
char buf[100];
volatile byte pos;
String DataIn;
char P[]="Data Processed \n";
int long time=millis();
 SPCR|=_BV(SPE);
 pos=0;
 process_it=false;
ISR(SPI_STC_vect)
   byte C=SPDR;
   if(stage==0)
       SPDR=C;
     if(pos<sizeof buf)
        buf[pos++]=C;
        if(C=='\n')
            process_it=true;
            stage=1;
            time=millis();
    else if(stage==1)
      SPDR=(byte)waitime;
      pos=0;
      stage=2;
    else if(stage==2)
         SPDR=P[pos];
         if(P[pos++]=='\n')
            stage=0;
            pos=0;
 if(process_it)
    buf[pos]=0;
    DataIn.concat(buf);
    pos=0;
    process_it=false;
    DataIn="";
This code works partially with only one exception still receiving 70 instead of 75
Fixed it and it broke again when i modified “GetDev(“FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF”);”
