I've connected everything correctly. SPI ports, 13,12,11,10 and then vin to 5V and GND to GND.
I've commented on the I2C code and uncommented the SPI code:
And it keeps giving me this error on the third line: redefinition of 'Adafruit_BMP3XX bmp'
In the I2C case I have plugged in SCK to A5 and SDI to A4. GND-GND and vin-5V. I've activated the I2C command and deactivated the SPI commands. All it prints out in serial is:
BMP388 test
Could not find a valid BMP3 sensor, check wiring!
When I tried the I2C code it just told me to check my wiring all the time
Sure, you must not uncomment two definitions. If you use hardware SPI uncomment the first one, if you use any other pins, uncomment the second one to activate a software emulation (much slower).
I am currently using an arduino uno and a bmp388 sensor.
As you link to the Adafruit site I assume you're using the breakout board from Adafruit and not the sensor directly. Is this assumption correct?
Why didn't you use the SDA/SCL pins as the Adafruit documentation suggests? On the UNO the connection is exactly the same but it eliminates a lot of error as experience here in the forum shows.
I tried the hardware SPI and the software SPI and neighter worked. Both gave the same answer
BMP388 test
And I have tried before hooking SCK to SCL on the arduino uno and SDI to SDA. But it gives the same result.
I think it might not be detecting the bmp388 becouse I haven't soldered it in any way. Currently using normal cables that I've stuck through the holes of the BMP388 into a breadbord. But it does make a sound on my computer when I plug in the GND cable.
The BMP388 doesn't have holes. I guess you're using some breakout board but you didn't answer my question about which one you're using.
Why do you expect your computer to make any sound? It would be a very bad sign if your computer makes sounds...
Post a sharp picture of your setup where all connections are clearly visible!
