SPI Connectivity Issues on ESP32-Wroom-32E with SD-Card
Hello Guys!
I have built a custom ESP32 PCB with the ESP32-WROOM-32E Chip. It is connected to a
Micro-SD-Card connector with its HSPI Pins:
MISO - IO12
MOSI - IO13
CLK - IO14
CS - IO15
I was trying to read a 1GB SD-Card with the connector, but it will not connect.
I took the ESP32 SD Example and changed it a little bit because of the pinout:
#include <SPI.h>
#include <SD.h>
#define SD_CS_PIN        15
// These pins will be use for SPI2
#define SD_CLK_PIN       14
#define SD_MOSI_PIN      13
#define SD_MISO_PIN      12
SPIClass SPI2(HSPI);
void listDir(fs::FS &fs, const char * dirname, uint8_t levels)
  Serial.printf("Listing directory: %s\n", dirname);
  File root = fs.open(dirname);
  if (!root)
    Serial.println("Failed to open directory");
    return;
  if (!root.isDirectory())
    Serial.println("Not a directory");
    return;
  File file = root.openNextFile();
  while (file)
    if (file.isDirectory())
      Serial.print("  DIR : ");
      Serial.println(file.name());
      if (levels)
        listDir(fs, file.path(), levels - 1);
      Serial.print("  FILE: ");
      Serial.print(file.name());
      Serial.print("  SIZE: ");
      Serial.println(file.size());
void createDir(fs::FS &fs, const char * path)
  Serial.printf("Creating Dir: %s\n", path);
  if (fs.mkdir(path))
    Serial.println("Dir created");
    Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char * path)
  Serial.printf("Removing Dir: %s\n", path);
  if (fs.rmdir(path))
    Serial.println("Dir removed");
    Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char * path)
  Serial.printf("Reading file: %s\n", path);
  File file = fs.open(path);
  if (!file)
    Serial.println("Failed to open file for reading");
    return;
  Serial.print("Read from file: ");
  while (file.available())
    Serial.write(file.read());
  file.close();
void writeFile(fs::FS &fs, const char * path, const char * message)
  Serial.printf("Writing file: %s\n", path);
  File file = fs.open(path, FILE_WRITE);
  if (!file)
    Serial.println("Failed to open file for writing");
    return;
  if (file.print(message))
    Serial.println("File written");
    Serial.println("Write failed");
  file.close();
void appendFile(fs::FS &fs, const char * path, const char * message)
  Serial.printf("Appending to file: %s\n", path);
  File file = fs.open(path, FILE_APPEND);
  if (!file)
    Serial.println("Failed to open file for appending");
    return;
    Serial.println("Message appended");
    Serial.println("Append failed");
  file.close();
void renameFile(fs::FS &fs, const char * path1, const char * path2)
  Serial.printf("Renaming file %s to %s\n", path1, path2);
  if (fs.rename(path1, path2))
    Serial.println("File renamed");
    Serial.println("Rename failed");
void deleteFile(fs::FS &fs, const char * path)
  Serial.printf("Deleting file: %s\n", path);
  if (fs.remove(path))
    Serial.println("File deleted");
    Serial.println("Delete failed");
void testFileIO(fs::FS &fs, const char * path)
  static uint8_t buf[512];
  size_t len = 0;
  uint32_t start = millis();
  uint32_t end = start;
  if (file)
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len)
      size_t toRead = len;
      if (toRead > 512)
        toRead = 512;
      file.read(buf, toRead);
      len -= toRead;
    end = millis() - start;
    Serial.printf("%u bytes read for %u ms\n", flen, end);
    file.close();
  if (!file)
    return;
  size_t i;
  start = millis();
  for (i = 0; i < 2048; i++)
    file.write(buf, 512);
  Serial.printf("%u bytes written for %u ms\n", 2048 * 512, end);
  file.close();
  while (!Serial && millis() < 5000);
  Serial.print(F("\nStart ESP32_SD_SPI2_FileTest on ")); Serial.println(ARDUINO_BOARD);
  Serial.println(F("Current SPI pinout:"));
  Serial.print(F("SD_MOSI_PIN:")); Serial.println(SD_MOSI_PIN);
  Serial.print(F("SD_MISO_PIN:")); Serial.println(SD_MISO_PIN);
  Serial.print(F("SD_CLK_PIN:"));  Serial.println(SD_CLK_PIN);
  Serial.print(F("SD_CS_PIN:"));   Serial.println(SD_CS_PIN);
  Serial.println("Serial communication started.");
  pinMode(SD_CS_PIN, OUTPUT); // SS
  if (!SD.begin(SD_CS_PIN, SPI2))
    Serial.println("Card Mount Failed");
    return;
  uint8_t cardType = SD.cardType();
  if (cardType == CARD_NONE)
    Serial.println("No SD card attached");
    return;
  Serial.print("SD Card Type: ");
  if (cardType == CARD_MMC)
    Serial.println("MMC");
  else if (cardType == CARD_SD)
    Serial.println("SDSC");
  else if (cardType == CARD_SDHC)
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  uint64_t cardSize = SD.cardSize() / (1024 * 1024);
  Serial.printf("SD Card Size: %lluMB\n", cardSize);
  listDir(SD, "/", 0);
  createDir(SD, "/mydir");
  removeDir(SD, "/mydir");
  listDir(SD, "/", 2);
  writeFile(SD, "/hello.txt", "Hello ");
  appendFile(SD, "/hello.txt", "World!\n");
  readFile(SD, "/hello.txt");
  deleteFile(SD, "/foo.txt");
  renameFile(SD, "/hello.txt", "/foo.txt");
  readFile(SD, "/foo.txt");
  testFileIO(SD, "/test.txt");
  Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
  Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
My problem is that i doesnt want to connect
It comes from this part of the code:
    return;
I would appreciate any kind of help!
Thanks :smiley:
It is probably an SDXC card which is not comparable with the SD library.
Why, i am using a 1GB SD card, which definitely has not the specs to be a advanced version. It should be a normal sd card.
But thanks for the comment
OOPS - misread 1GB as 1TB, I haven't seen a card that small in awhile.
Does the card work with other systems? Can you read/write it on a PC for example?
I found that the default HSPI pins are not working for me, so once i switched to use an alternate pinout i got it to work.
#define LED_YELLOW 2
#define HSPI_SCK 17
#define HSPI_MISO 16
#define HSPI_MOSI 4
#define SD_CS 15
#define SPI_FRQ 32000000
#define TEST_BLOCKS 4
#include "FS.h"
#include "SD.h"
#include "SPI.h"
SPIClass * hspi = NULL;
  pinMode(LED_YELLOW, OUTPUT);
  digitalWrite(LED_YELLOW, LOW);  // active LOW
  hspi = new SPIClass(HSPI);
  hspi->begin(HSPI_SCK, HSPI_MISO, HSPI_MOSI, SD_CS);
  hspi->setFrequency(SPI_FRQ);
  //hspi->begin();
  if (!SD.begin(SD_CS, *hspi, SPI_FRQ)) {
    return;
  if (cardType == CARD_NONE) {
    return;
  if (cardType == CARD_MMC) {
  } else if (cardType == CARD_SD) {
  } else if (cardType == CARD_SDHC) {
  digitalWrite(LED_YELLOW, HIGH);  // active LOW
void listDir(fs::FS &fs, const char * dirname, uint8_t levels) {
  if (!root) {
    return;
  if (!root.isDirectory()) {
    return;
  while (file) {
    if (file.isDirectory()) {
      if (levels) {
        listDir(fs, file.name(), levels - 1);
void createDir(fs::FS &fs, const char * path) {
  if (fs.mkdir(path)) {
void removeDir(fs::FS &fs, const char * path) {
  if (fs.rmdir(path)) {
void readFile(fs::FS &fs, const char * path) {
  if (!file) {
    return;
  while (file.available()) {
  file.close();
void writeFile(fs::FS &fs, const char * path, const char * message) {
  if (!file) {
    return;
  if (file.print(message)) {
  file.close();
void appendFile(fs::FS &fs, const char * path, const char * message) {
  if (!file) {
    return;
  file.close();
void renameFile(fs::FS &fs, const char * path1, const char * path2) {
  if (fs.rename(path1, path2)) {
void deleteFile(fs::FS &fs, const char * path) {
  if (fs.remove(path)) {
void testFileIO(fs::FS &fs, const char * path) {
  size_t len = 0;
  uint32_t ustart = micros();
  uint32_t uend = start;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    ustart = micros();
    while (len) {
      if (toRead > 512) {
        toRead = 512;
      len -= toRead;
    uend = micros() - ustart;
    if (end > 100) Serial.printf("%u bytes read for %u ms\n", flen, end);
    else Serial.printf("%u bytes read for %u us\n", flen, uend);
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  ustart = micros();
  for (i = 0; i < TEST_BLOCKS; i++) {
  if (end > 100) Serial.printf("%u bytes written for %u ms\n", TEST_BLOCKS * 512, end);
  else Serial.printf("%u bytes written for %u us\n", TEST_BLOCKS * 512, uend);
  file.close();
also in your sketch.
this is not needed the sd library will take care of that.
And i think somehow that you do need to call
SPI2.begin();
you can modify the pinmap there as well. I use a system with a pointer to the object, but it is the same.
