I have been playing with SPI on the Galileo. Though the SPI clock is fast, the time from when CS goes low to when the clock & data starts is about 3ms! that is far to long to wait for the data to start. The time for the 8 bits to be clocked out is just a mere 60us. I would expect CS to data time to be much less than this. Is there a another way to shorten this time ?
digitalWrite(CS, LOW );
SPI.transfer(DEVICE_ID_DATA);
digitalWrite(CS, HIGH );
After the data, there is another 2ms before CS goes high again.
I see that there is a fastGpioSCInit(), but so far i have been unable to get it to toggle a pin.
I took a look at the SPI driver source, seems short and sweet to me, but i am not sure on that linux call stuff.
If i change the above code to this, by adding the digitalWrite(10, LOW); directly in there it still end up being about the same.
I am thinking its the digitalWrite, that is taking so long, but i cannot find the source for it.
Oh, I didn't realise this is running under an OS, all bets are off then I think.
Maybe a Linux guru can tell us how to bypass all the scheduling gumpf and write directly to the hardware, if that's even possible without casing a hard fault.
I believe i found the culprit. Its in the file wiring_digital.c This is where digitalWrite lives. Code at end. This IMHO is a very bloated and slow way to toggle an IO pin quickly (sure its safe) but i want fast. First it has to call pinGetIndex(pin);, then it calls digitalWriteSetVal(idx, pin, val); which is then calling fastGpioDigitalWrite(); i...yi...yi... just change the state already.....
Far to many function calls. I should be able to call fastGpioDigitalWrite directly but at the moment i have no idea what pin8 is translated to for the call .
I am not an expert on the Gallileo, but there seems to be an issue with the speed of setting the digital output bits ( which would presumably include the CS signal to the slave device, here ? ), because there is no direct GPIO, it is connected through I2C. Someone else was complaining about that, last week.
@michinyon , thanks i am aware. but still all in all if i can bypass all that function calls digitalWrite does and merely call fastGpioDigitalWrite myself, i should be able to gain allot of speed.
