SPI data sent by slave is not constintent
I am trying to code my Arduino Mega2560 in slave mode using SPI and SPI_anything.h library to send a struct of one byte and six int16s to a Raspberry that is coded using Simulink support package. Arduino reads the sensors and need to feed RPi which is the master controller of a robotic platform.
I have followed Gammon's forum where he explaines the SPI_anything library.
This is my struct definition
typedef struct myStruct //1x7 size array
  byte expe_spi_time;
  int16_t IMU_ori;
  int16_t IMU_ang_vel;
  int16_t enc_count_int16;       //       int16_t enc_count;
  int16_t knee_pot_meas;     //        int16_t knee_pot_meas;
  int16_t curfed_4V;           //  int16_t curfed_4V;
  int16_t accelero_z_ms2;
volatile myStruct from_simulink_rpi;
volatile myStruct buff;
volatile bool haveData;
and this is my interrupt service routine.
ISR (SPI_STC_vect) {
  //SPI_readAnything_ISR (from_simulink_rpi) ;
  SPDR = 1 ;
  //delayMicroseconds(1);
  SPI_writeAnything (buff);
  haveData = true;
The problem is: When I use these codes with an easy handled (Two lines of +10 addition to some values to check from the master side if it is working) with a large delay (around 10 ms) in the void loop, everything works well, I receive all the data at my Simulink screen via running Raspberry Pi in external mode.
When I add my encoder and some I2C sensors in the loop to send to the master, data received at the master is very distorted. (Sensors and everything works fine, I check the readings in serial monitor)
What I mean by distorted is: The byte ordering changes randomly and causes ill readings for all 6 values that jumps around. For small brief moments some read values matches with the ones that is send from the Arduino but the problem is the consistency.
I tried adding some delaymicroseconds between SPDR commands in the .h file but it sometimes fix the problem temporarly, nothing consistent.
Any ideas why this can happen?
Cheers.
Are you sure the hardware is correct? If not post a schematic, not a frizzy thing with links to the technical side of each hardware item.
