Does anybody know why a SPI TFT Display does not work with ESP32 using the library Espalexa.h ? It seams to be some kind of conflict between timers pins maybe used by Espalexa.h and SPI pins... but I can not be sure about that suspecius... My SPI pins are those standars: CS=15, RST=4, DC=2, MOSI=23, CLK=17, MISO=19, without any other connection. After Espalexa functions are called the display shows only strange things and colors !!!
I also tried some other pins for CS but the result was the same...
Help us help you.
If you are using a 9V battery like this.
Don't.
I2C scanner
What did the I2C scanner report?
Bread board power rail split
Serial Input basics.
The search box is a useful tool.
For instance, using the words "9v battery" in the search box one could find lots of reasons why this may be a bad idea.
Other search words include "level shifter", "round", "millis()",
code merging
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
disclaimer
The events portrayed in this post are not all true. The names are not real names of real people and real organizations.
Servo stuff
Power externally.
power distribution blocks.
Your long and detailed suggestion & rules does not apply to my case but thanks anyway !!!
