Hello
I want to use a display and the timer1 interrupt together but it does not work.
Without any timer initialization the Oled display works fine an displays a "T" for test. With the timer initialization the display displays nothing. When the TIMSK1 is activated in code the display does not work anymore. When i comment the TIMSK1 out it works and shows a "T" for test on the display but the timer won't work without enabling TIMSK1.
Why does the display not work together with the initialization of the timer?
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for SSD1306 display connected using software SPI (default case):
#define OLED_MOSI 9
#define OLED_CLK 10
#define OLED_DC 11
#define OLED_CS 12
#define OLED_RESET 13
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,
OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
//Timer interrupts
cli();//stop interrupts
//set timer1 interrupt at 1Hz
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;//initialize counter value to 0 --> counter Register
// set compare match register for 50hz increments
OCR1A = 40000;// bis hierhin zählt deer counter, dannach macht er einen Reset 16MHZ / prescaler / gewählte HZ
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS10 and CS12 bits for 8 prescaler
TCCR1B |= (0 << CS12) | (1 << CS11) | (0 << CS10);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A); // -->When i comment out this row the display works and with this not.<--
sei();//allow interrupts
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC))
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
Test();//Gives out a "T" on display!
void Test(void)
display.clearDisplay();
display.setTextSize(1); // Draw 2X-scale text
display.setTextColor(SSD1306_WHITE);
display.setCursor(0, 0);
display.println("T");
display.display();
I controlled the data connection of the hardware. The arduino sends data to the display when TIMSK1 is comment out. And the arduino doesn't send data to the display when Timsk1 is active.
Someone an idea?
