Hi all,
I'm trying to do some data logging to an Atmel AT25640A eeprom using SPI. I've got the interface up and running no problem, but I can't seem to address more than 256 memory locations.
The AT25640A is an 8x8192 (64kbit) chip, but I get wrap around at multiples of 256 if i write to location 0 (so addresses 0, 256, 512, 768, ... have the same value). I've tried twiddling various data types, but no luck. My code's below, which mostly follows the SPI EEPROM tutorial on the Arduino site for the AT25HP512 (same instruction set).
//Test how many slots there are to print times to
#define DATAOUT 11 //MOSI
#define DATAIN 12 //MISO
#define SPICLOCK 13 // SCK
#define SS0 10//Slave select 0
//Opcodes
#define WREN 6 //write enable
#define WRDI 4 //write disable
#define RDSR 5 //read status register
#define WRSR 1 //write status register
#define READ 3 //read
#define WRITE 2//write
byte clr;
byte test = 0b1;
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK, OUTPUT);
pinMode(SS0, OUTPUT);
digitalWrite(SS0, HIGH); //disable device
//SPCR = 0101000
SPCR = (1<<SPE)|(1<<MSTR);
clr = SPSR; //clear spi status register
clr = SPDR; // clear spi data register
delay(10); //wait for eeprom to finish writing
Serial.println("serial active\n");
/*Serial.print("clearing eeprom: ");
for (int i = 0; i<8192; i++){
write_eeprom(i, 0b0);
Serial.print(i, DEC);
Serial.print(", ");
Serial.println("...done");
Serial.print("writing to eeprom");
write_eeprom(0, test);
void loop(){
int i =0;
byte data;
for (i=0; i<8192; i++){
data = read_eeprom(i);
if (data == test || data == -1){
Serial.print(":");
Serial.print(data, DEC);
Serial.print("\t");
} else { continue;}
delay(10);
Serial.println("\nPause in loop");
delay(5000);
unsigned int spi_transfer(volatile unsigned int data){
SPDR = data;
while (!(SPSR & (1<<SPIF)))
return SPDR;
void write_eeprom(unsigned int EEPROM_address, byte data){
digitalWrite(SS0, LOW); //select device
spi_transfer((char)(WREN)); //write enable
delay(10);
spi_transfer((char)(WRITE)); //write
spi_transfer((EEPROM_address+1)); //MSB
spi_transfer((EEPROM_address)); //LSB
spi_transfer((char)(data));
delay(10); //wait for EEPROM to finish writing
byte read_eeprom(unsigned int EEPROM_address){
spi_transfer((char)(READ));
spi_transfer((EEPROM_address)); //lsb
byte data = (char)(spi_transfer(0xFF));
return data;
Thanks in advance!
