Hello,
I'm trying to interface an AT25256 EEPROM to my Arduino for a project but I'm having no luck. I can write the first 64 bytes no problem, but then when I write to address 64 it wraps around and writes to address 01 again.
To test my hardware I'm us the "Interfacing a Serial EEPROM Using SPI" code from the arduino site. http://arduino.cc/en/Tutorial/SPIEEPROM
I'm using an at25256 but the EEPROM from the example code I use is a AT25HP512. Could this be by problem?
This is my first go at SPI so I'm well out of my depth here, any help would be appreciated.
#define DATAOUT 11//MOSI
#define DATAIN 12//MISO
#define SPICLOCK 13//sck
#define SLAVESELECT 10//ss
//opcodes
#define WREN 6
#define WRDI 4
#define RDSR 5
#define WRSR 1
#define READ 3
#define WRITE 2
byte eeprom_output_data;
byte eeprom_input_data=0;
byte clr;
int address=0;
//data buffer
char buffer [128];
void fill_buffer()
for (int I=0;I<128;I++)
buffer[I]=I;
char spi_transfer(volatile char data)
SPDR = data; // Start the transmission
while (!(SPSR & (1<<SPIF))) // Wait the end of the transmission
return SPDR; // return the received byte
pinMode(DATAOUT, OUTPUT);
pinMode(DATAIN, INPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(SLAVESELECT,OUTPUT);
digitalWrite(SLAVESELECT,HIGH); //disable device
// SPCR = 01010000
//interrupt disabled,spi enabled,msb 1st,master,clk low when idle,
//sample on leading edge of clk,system clock/4 rate (fastest)
SPCR = (1<<SPE)|(1<<MSTR);
clr=SPSR;
clr=SPDR;
delay(10);
//fill buffer with data
fill_buffer();
//fill eeprom w/ buffer
digitalWrite(SLAVESELECT,LOW);
spi_transfer(WREN); //write enable
delay(10);
spi_transfer(WRITE); //write instruction
address=0;
spi_transfer((char)(address>>8)); //send MSByte address first
spi_transfer((char)(address)); //send LSByte address
//write 128 bytes
spi_transfer(buffer[I]); //write data byte
digitalWrite(SLAVESELECT,HIGH); //release chip
//wait for eeprom to finish writing
delay(3000);
Serial.print('h',BYTE);
Serial.print('i',BYTE);
Serial.print('\n',BYTE);//debug
byte read_eeprom(int EEPROM_address)
//READ EEPROM
int data;
spi_transfer(READ); //transmit read opcode
spi_transfer((char)(EEPROM_address>>8)); //send MSByte address first
spi_transfer((char)(EEPROM_address)); //send LSByte address
data = spi_transfer(0xFF); //get data byte
digitalWrite(SLAVESELECT,HIGH); //release chip, signal end transfer
return data;
eeprom_output_data = read_eeprom(address);
Serial.print(eeprom_output_data,DEC);
address++;
if (address == 128)
address = 0;
delay(500); //pause for readability
