SPI Ethernet iperf speed on Mega and ESP32 wifi and LAN8720
I got a W5500 on a Mega board. (pin 10 is used as SS). 2.66 Mbits/sec
Also tested on ESP32 WI-FI 13.0 Mbits/sec
Ethernet LAN8720 ESP32 36 Mbits/sec
W5500 ESP32 12 Mbits/sec Good enough for me!
All fine but i am curiour about my results using iperf to test it, can you try some Ethernet setups and share the results with this iperf code?
Thanks
#include <SPI.h>
#include <Ethernet2.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network.
// gateway and subnet are optional:
// http://www.instructables.com/id/How-to-measure-Arduino-network-performance/
// On windows CMD: iperf -c 192.168.22.117 -w 16k -t 20 -i 2
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 22, 117);
IPAddress gateway(192, 168, 22, 1);
IPAddress dns_server(192, 168, 22, 1);
IPAddress subnet(255, 255, 0, 0);
EthernetServer server(5001);
  Ethernet.begin(mac, ip);
  server.begin();
  while (!Serial) {
  Serial.print("Iperf server address : ");
  Serial.println(Ethernet.localIP());
  Serial.println(" ");
  byte buf[1024];
  if (client) {
    Serial.println("Here is new client for check arduino performance");
    while (client.connected()) {
      if (client.available()) client.read(buf, 1024);
    client.stop();
    Serial.println("client disonnected");
On windows CMD:
My results W5500/Mega:
C:\Users\Quad>iperf -c 192.168.22.117 -w 16k -t 20 -i 2
Client connecting to 192.168.22.117, TCP port 5001
TCP window size: 16.0 KByte
[ 3] local 192.168.22.115 port 50366 connected with 192.168.22.117 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0- 2.0 sec 768 KBytes 3.15 Mbits/sec
[ 3] 2.0- 4.0 sec 640 KBytes 2.62 Mbits/sec
[ 3] 4.0- 6.0 sec 640 KBytes 2.62 Mbits/sec
[ 3] 6.0- 8.0 sec 640 KBytes 2.62 Mbits/sec
[ 3] 8.0-10.0 sec 640 KBytes 2.62 Mbits/sec
[ 3] 10.0-12.0 sec 640 KBytes 2.62 Mbits/sec
[ 3] 12.0-14.0 sec 640 KBytes 2.62 Mbits/sec
[ 3] 14.0-16.0 sec 640 KBytes 2.62 Mbits/sec
[ 3] 16.0-18.0 sec 640 KBytes 2.62 Mbits/sec
[ 3] 18.0-20.0 sec 640 KBytes 2.62 Mbits/sec
[ 3] 0.0-20.1 sec 6.38 MBytes 2.66 Mbits/sec
On ESP32 WI-FI:
C:\Users\Quad>iperf -c 192.168.22.143 -w 16k -t 20 -i 2 -p 5001
Client connecting to 192.168.22.143, TCP port 5001
[ 3] local 192.168.22.115 port 52743 connected with 192.168.22.143 port 5001
[ 3] 0.0- 2.0 sec 2.50 MBytes 10.5 Mbits/sec
[ 3] 2.0- 4.0 sec 3.00 MBytes 12.6 Mbits/sec
[ 3] 4.0- 6.0 sec 3.12 MBytes 13.1 Mbits/sec
[ 3] 6.0- 8.0 sec 3.12 MBytes 13.1 Mbits/sec
[ 3] 8.0-10.0 sec 3.00 MBytes 12.6 Mbits/sec
[ 3] 10.0-12.0 sec 2.88 MBytes 12.1 Mbits/sec
[ 3] 12.0-14.0 sec 3.38 MBytes 14.2 Mbits/sec
[ 3] 14.0-16.0 sec 3.38 MBytes 14.2 Mbits/sec
[ 3] 16.0-18.0 sec 3.38 MBytes 14.2 Mbits/sec
[ 3] 18.0-20.0 sec 3.38 MBytes 14.2 Mbits/sec
[ 3] 0.0-20.0 sec 31.1 MBytes 13.0 Mbits/sec
Over Ethernet LAN8720 ESP32
Client connecting to 192.168.22.125, TCP port 5001
[ 3] local 192.168.22.114 port 60201 connected with 192.168.22.125 port 5001
[ 3] 0.0- 2.0 sec 8.00 MBytes 33.6 Mbits/sec
[ 3] 2.0- 4.0 sec 8.12 MBytes 34.1 Mbits/sec
[ 3] 4.0- 6.0 sec 8.25 MBytes 34.6 Mbits/sec
[ 3] 6.0- 8.0 sec 8.25 MBytes 34.6 Mbits/sec
[ 3] 8.0-10.0 sec 8.25 MBytes 34.6 Mbits/sec
[ 3] 10.0-12.0 sec 8.25 MBytes 34.6 Mbits/sec
[ 3] 12.0-14.0 sec 8.25 MBytes 34.6 Mbits/sec
[ 3] 14.0-16.0 sec 8.25 MBytes 34.6 Mbits/sec
[ 3] 16.0-18.0 sec 8.25 MBytes 34.6 Mbits/sec
[ 3] 18.0-20.0 sec 8.50 MBytes 35.7 Mbits/sec
[ 3] 0.0-20.0 sec 82.4 MBytes 34.5 Mbits/sec
Over Ethernet W5500 ESP32
Client connecting to 192.168.22.177, TCP port 5001
[ 3] local 192.168.22.114 port 51495 connected with 192.168.22.177 port 5001
[ 3] 0.0- 2.0 sec 2.75 MBytes 11.5 Mbits/sec
[ 3] 2.0- 4.0 sec 2.75 MBytes 11.5 Mbits/sec
[ 3] 4.0- 6.0 sec 2.62 MBytes 11.0 Mbits/sec
[ 3] 6.0- 8.0 sec 2.75 MBytes 11.5 Mbits/sec
[ 3] 8.0-10.0 sec 2.75 MBytes 11.5 Mbits/sec
[ 3] 10.0-12.0 sec 2.62 MBytes 11.0 Mbits/sec
[ 3] 12.0-14.0 sec 2.75 MBytes 11.5 Mbits/sec
[ 3] 14.0-16.0 sec 2.62 MBytes 11.0 Mbits/sec
[ 3] 16.0-18.0 sec 2.75 MBytes 11.5 Mbits/sec
[ 3] 18.0-20.0 sec 2.75 MBytes 11.5 Mbits/sec
[ 3] 0.0-20.1 sec 27.1 MBytes 11.3 Mbits/sec
dear danielt514,
thank you for your data , i have a project with esp32 can you tell me the pin out for esp32 and library
thanks a lot
