SPI exchange pin?
Hello, i'm working on a Arduino duemilanove. And I would like to know if it's possible to exchange some pins in the SPI protocol..? In place of,
13 Spi Clock 12 (Datain) //not used 11 Dataout 10 Slaveselect
I would like to define:
13 Spi Clock 12 Dataout 11 Slaveselect1 10 Slaveselect2 7 (Datain)
I just try to exchange Datain and Dataout,... but the Dataout signal don't seems to work in this configuration on my oscilloscope,...?
Any Idea? thanks
Hi Jerome.
No, this is not possible when using the Hardware SPI feature of the ATMega.
But if you don't need to read back any data through the DataIn-pin you can code the SPI-Protocol in software by simply toggling any pin you like. It will be much slower than the Hardware SPI (Clock is in the 100Khz range), but you have full control of the pins used.
I did this for a SPI-driven LCD http://code.google.com/p/doglcd/ and for a LedMatrix driver chip http://www.arduino.cc/playground/Main/LedControl
Its fast enough for these two projects
Eberhard
Thank you for your reply.
Indeed, impossible to exchange spi pin of places (13,12,11,10),…except that you can add more than one slave select on the desired pin you want.
and if you dont use the MOSI or MISO pin, you can assign it for another use.
right?
thanks.
indeed, impossible to exchange spi pin of places (13,12,11,10),...except that you can add more than one slave select on the desired pin you want.
Yes, you can use any other digital pin to select the slave you want to talk to.
No, the MOSI and MISO pins are not available for "normal" IO when you activate the Hardware-SPI module.
Eberhard
