SPI for ATtiny85
Hi there,
I'm using a ATtiny85 to control a slave device through SPI. This code I have wrote does work to control the slave device using the arduino. I now want to upload this program to the ATtiny85 however the tiny's SPI library doesn't work with some of the commands in the code. These commands being;
SPI.setBitOrder(MSBFIRST)
SPI.setClockDivider(SPI_CLOCK_DIV64)
Is there anything else I can use to do the same thing. Someone has mentioned using the shiftOut command.
Any help would be appreciated.
#include "tinySPI.h"
int ss=4; //pin 3 on ATtiny85
int del=20; //delay for various delays
pinMode(ss, OUTPUT);
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
SPI.setClockDivider(SPI_CLOCK_DIV128);
digitalWrite(ss, LOW);
SPI.transfer(0x4E);
SPI.transfer(0x00);
SPI.transfer(0x03);
digitalWrite(ss, HIGH);
delay(del);
while(1);
Is there a specific reason you're using the tinySPI library? If you use ATTinyCore, it comes with its own version of the standard SPI library.
Note this from the SPI library's documentation:
https://www.arduino.cc/en/Reference/SPISetBitOrder
https://www.arduino.cc/en/Reference/SPISetClockDivider
This function should not be used in new projects. Use SPISettings with SPI.beginTransaction() to configure SPI parameters.
