//please ignore comments, as the code is modified so frequently that I forget about comments!
#include <avr/interrupt.h>
#include <avr/io.h>
#include <SPI.h>
volatile byte matrica[8][3];
volatile byte counting1;
volatile byte counting2;
volatile byte bitek;
volatile byte counter=0;
SPI.setBitOrder(MSBFIRST);
SPI.setDataMode(SPI_MODE0);
SPI.setClockDivider(SPI_CLOCK_DIV2);
pinMode(4, OUTPUT);
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
//Serial.begin(57600);
TIMSK1 = 0;
// TIMER 1 CTC mode
TCCR1A = 0; // CORRECT
TCCR1B |= (1<<WGM12); // CORRECT
/* IZBERI IZVOR URE ZA TIMER 2, IZVOR JE MULTIPLEXER */
//ASSR &= ~(1<<AS2);
/* Enable Compare Match A interrupt enable */
//TIFR2 |= (1<<OCF2A);
/* Now configure the prescaler to CPU clock divided by 64 */
TCCR1B &= ~(1<<CS12); //
TCCR1B |= (1<<CS11); // 001 - prescaler -2 ??
TCCR1B &= ~(1<<CS10); //
SPCR |= (0<<SPIE);
for(counting1=0;counting1<4;counting1++)
for(counting2=0;counting2<3;counting2++)
{ matrica[counting1][counting2]=1;
matrica[counting1+4][counting2]=255;
TCNT1 = 0;
OCR1A = 255;
TIMSK1 |= (1<<OCIE1A);// correczt
sei();
bitek=0;
SPI.begin();
volatile byte krneki=0;
volatile void dilej() { krneki=0; while(krneki > 20) {krneki++;} }
ISR(TIMER1_COMPA_vect)
switch(bitek)
case 0: bitek=1;
OCR1A=2; TCNT1 = 0;
SPI.transfer(matrica[0][1]); dilej();
SPI.transfer(matrica[0][2]); dilej();
SPI.transfer(matrica[0][3]); dilej();
break;
case 1: bitek=2;
OCR1A=2; TCNT1 = 0;
SPI.transfer(matrica[1][1]); dilej();
SPI.transfer(matrica[1][2]); dilej();
SPI.transfer(matrica[1][3]); dilej();
break;
case 2: bitek=3;
OCR1A=4; TCNT1 = 0;
SPI.transfer(matrica[2][1]); dilej();
SPI.transfer(matrica[2][2]); dilej();
SPI.transfer(matrica[2][3]); dilej();
break;
case 3: bitek=4;
OCR1A=8; TCNT1 = 0;
SPI.transfer(matrica[3][1]); dilej();
SPI.transfer(matrica[3][2]); dilej();
SPI.transfer(matrica[3][3]); dilej();
break;
case 4: bitek=5;
OCR1A=16; TCNT1 = 0;
SPI.transfer(matrica[4][1]); dilej();
SPI.transfer(matrica[4][2]); dilej();
SPI.transfer(matrica[4][3]); dilej();
break;
case 5: bitek=6;
OCR1A=32; TCNT1 = 0;
SPI.transfer(matrica[5][1]); dilej();
SPI.transfer(matrica[5][2]); dilej();
SPI.transfer(matrica[5][3]); dilej();
break;
case 6: bitek=7;
OCR1A=64; TCNT1 = 0;
SPI.transfer(matrica[6][1]); dilej();
SPI.transfer(matrica[6][2]); dilej();
SPI.transfer(matrica[6][3]); dilej();
break;
case 7: bitek=8;
OCR1A=255; TCNT1 = 0;
SPI.transfer(matrica[7][1]); dilej();
SPI.transfer(matrica[7][2]); dilej();
SPI.transfer(matrica[7][3]); dilej();
break;
case 8: bitek=9;
break;
case 9: bitek=10;
break;
case 10:bitek=11;
break;
case 11:bitek=12;
OCR1A=8; TCNT1 = 0;
break;
case 12: bitek=13;
OCR1A=4; TCNT1 = 0;
break;
case 13: bitek=0;
OCR1A=2; TCNT1 = 0;
break;
default: bitek=0; break; //?e se je slu?ajno kaj sfukalo, resetiramo bitek na 0
PORTB |= 0b00000100; // <-latch_on
PORTB &= 0b11111011; // <-latch_off
I know, what a mess
