SPI input, anyway to shift the bits?
Is there anyway to tell the SPI interface to ignore or shift over the bits coming in?
I have a sensor that is a simple two wire SPI style interface. The arduino feeds it a clock signal, and the sensor feeds back data, one bit per clock tick
the problem is, the sensor sends back data in the format
- device is settling in and getting data to send
<a random number of 0xff bytes> - device about to send data
- start the header, always the same - always the same start the cycle again... ....
I've been using the SPI fuction, but finding that I have a problem with the data.
0xAA - 10101010 This is what I want
getting
0x54 - 01010100
0xD5 - 11010101
0xEA - 11101010
0xF5 - 11110101
0xFA - 11111010
oxFD - 11111101
0xFE - 11111110
So the sensor is sending the data, but the arduino is somehow shifted over a random number of bits.
I could do bit banging and try it that way, but I would like to run it fast in the 1 to 2MHZ clock range.
So if I can't tell the SPI hardware to shift over, does anyone have any really tight bit-bang code they could recommend?
In short no.
Are you sure this is correct? It doesn't seem like the intended behavioured of a device. Make sure you have set the SPI to shift in the data on the edge of the clock that the device is expecting it to use.
What happens if you bit bang until you get your 0xAA and then use the SPI for speed?
Does the peripheral even support "1 to 2MHz" ?
Is the thing true SPI? Which SPI mode does it want (clock polarity and clock phase setting combine to give 4 different SPI modes)? What is its max clock rate?
-j
this partiular device is a camera module, that pumps out the pixel data one bit at a time. Orginally designed to work at a 1MHz clock, I've seen some mention that it's been tested up to 1.5MHz. The nice thing is that it handles slower clock cycles as well, down into the 50KHz range.
The problem is that the device sends out a random number of "1"s (but no less than 500+ bytes worth) between each image. then it comes back to the 0xaa header.
The device updates on the rising edge of the clock, so read on the falling edge. I didn't find any info on if the clock should be high or low during idle, and I've been keeping it low and that seems to work.
testing has shown that the average for one picture is approx 178K bits, give or take 1K. of that, the actual data is 172800 bits with the remaing 5 to 6K bits the header/filler. That is a lot of manual bit banging. I'm trying to offload as much as possible to the hardware SPI.
Hoping to make a blob tracker with it. Heh. Might be stressing the little arduino a bit much for that. Normally you would write comething like this in pure "C" and hand optimize the the resulting assembler. If I can get it working at 500KHz, that would be a bit under 3 frames a second. a bit slow but still amazing for this little guy.
So the current plan is that when I'm in the startup phase, bit bang each bit individually until I get to the known header data. once I'm there, figure out where I am (with lots of bitwise math) and once I know that the next bit is the start of a known header byte, fire up the SPI and let it pull the bytes until I reach the end of one picture dataset, a known number of bytes at that point. meanwhile while that's going on process the incoming data and track those blobs.
We shall see if I can make it work.
If it's only capable of 1MHz (or so), you can bit bang it with no problem.
Looks to me as if the 178k image on a 1k RAM microcontroller might be the challenge, rather than the bit-banged communications...
good luck!
-j
