Hello everyone, i read a lot of topyc but my problem is still there,
I use an arduino UNO with Ethernet shield 2 and i use an 8Mo sd card. I connect my arducam with the classic connection like in the image.
and here is the arducam exemple i use (i just change the SD_CS at 4 bc of the sheild)
// ArduCAM Mini demo (C)2017 Lee
// Web: http://www.ArduCAM.com
// This program is a demo of how to use the enhanced functions
// This demo was made for ArduCAM_Mini_5MP_Plus.
// It can continue shooting and store it into the SD card in JPEG format
// The demo sketch will do the following tasks
// 1. Set the camera to JPEG output mode.
// 2. Capture a JPEG photo and buffer the image to FIFO
// 3.Write the picture data to the SD card
// 5.close the file
//You can change the FRAMES_NUM count to change the number of the picture.
//IF the FRAMES_NUM is 0X00, take one photos
//IF the FRAMES_NUM is 0X01, take two photos
//IF the FRAMES_NUM is 0X02, take three photos
//IF the FRAMES_NUM is 0X03, take four photos
//IF the FRAMES_NUM is 0X04, take five photos
//IF the FRAMES_NUM is 0X05, take six photos
//IF the FRAMES_NUM is 0X06, take seven photos
//IF the FRAMES_NUM is 0XFF, continue shooting until the FIFO is full
//You can see the picture in the SD card.
// This program requires the ArduCAM V4.0.0 (or later) library and ArduCAM_Mini_5MP_Plus
// and use Arduino IDE 1.6.8 compiler or above
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include <SD.h>
#include "memorysaver.h"
//This demo can only work on OV5640_MINI_5MP_PLUS or OV5642_MINI_5MP_PLUS platform.
#if !(defined (OV5640_MINI_5MP_PLUS)||defined (OV5642_MINI_5MP_PLUS))
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
#define FRAMES_NUM 0x06
// set pin 7 as the slave select for the digital pot:
const int CS = 7;
#define SD_CS 4
bool is_header = false;
int total_time = 0;
#if defined (OV5640_MINI_5MP_PLUS)
ArduCAM myCAM(OV5640, CS);
#else
ArduCAM myCAM(OV5642, CS);
#endif
uint8_t read_fifo_burst(ArduCAM myCAM);
uint8_t vid, pid;
uint8_t temp;
#if defined(__SAM3X8E__)
Wire1.begin();
#else
Wire.begin();
#endif
Serial.println(F("ArduCAM Start!"));
// set the CS as an output:
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
// initialize SPI:
SPI.begin();
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while(1){
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if(temp != 0x55)
Serial.println(F("SPI interface Error!"));
delay(1000);continue;
}else{
Serial.println(F("SPI interface OK."));break;
while(1){
//Check if the camera module type is OV5640
myCAM.rdSensorReg16_8(OV5640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV5640_CHIPID_LOW, &pid);
if ((vid != 0x56) || (pid != 0x40)){
Serial.println(F("Can't find OV5640 module!"));
delay(1000); continue;
}else{
Serial.println(F("OV5640 detected."));break;
#else
while(1){
//Check if the camera module type is OV5642
myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
if ((vid != 0x56) || (pid != 0x42)){
Serial.println(F("Can't find OV5642 module!"));
}else{
Serial.println(F("OV5642 detected."));break;
#endif
//Initialize SD Card
while(!SD.begin(SD_CS))
Serial.println(F("SD Card Error!"));delay(1000);
Serial.println(F("SD Card detected."));
//Change to JPEG capture mode and initialize the OV5640 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.set_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES, FRAMES_NUM);
myCAM.flush_fifo();
myCAM.OV5640_set_JPEG_size(OV5640_320x240);delay(1000);
#else
myCAM.OV5642_set_JPEG_size(OV5642_320x240);delay(1000);
#endif
//Start capture
myCAM.start_capture();
Serial.println(F("start capture."));
total_time = millis();
while ( !myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
Serial.println(F("CAM Capture Done."));
total_time = millis() - total_time;
Serial.print(F("capture total_time used (in miliseconds):"));
Serial.println(total_time, DEC);
read_fifo_burst(myCAM);
Serial.print(F("save capture total_time used (in miliseconds):"));
//Clear the capture done flag
delay(5000);
uint8_t temp = 0, temp_last = 0;
uint32_t length = 0;
static int i = 0;
static int k = 0;
char str[8];
File outFile;
byte buf[256];
length = myCAM.read_fifo_length();
Serial.print(F("The fifo length is :"));
Serial.println(length, DEC);
if (length >= MAX_FIFO_SIZE) //8M
Serial.println("Over size.");
return 0;
if (length == 0 ) //0 kb
Serial.println(F("Size is 0."));
return 0;
myCAM.CS_LOW();
myCAM.set_fifo_burst();//Set fifo burst mode
i = 0;
while ( length-- )
temp_last = temp;
temp = SPI.transfer(0x00);
//Read JPEG data from FIFO
if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
buf[i++] = temp; //save the last 0XD9
//Write the remain bytes in the buffer
myCAM.CS_HIGH();
outFile.write(buf, i);
//Close the file
outFile.close();
Serial.println(F("OK"));
is_header = false;
myCAM.CS_LOW();
i = 0;
if (is_header == true)
//Write image data to buffer if not full
if (i < 256)
buf[i++] = temp;
//Write 256 bytes image data to file
myCAM.CS_HIGH();
outFile.write(buf, 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
else if ((temp == 0xD8) & (temp_last == 0xFF))
is_header = true;
myCAM.CS_HIGH();
//Create a avi file
k = k + 1;
itoa(k, str, 10);
strcat(str, ".jpg");
//Open the new file
outFile = SD.open(str, O_WRITE | O_CREAT | O_TRUNC);
if (! outFile)
Serial.println(F("File open failed"));
while (1);
myCAM.CS_LOW();
buf[i++] = temp_last;
buf[i++] = temp;
myCAM.CS_HIGH();
return 1;
I hope someone could know how to fix my issues
Have great day
