SPI interface Error
Hello, I have this program
// ArduCAM Mini demo (C)2016 Lee
// web: http://www.ArduCAM.com
// This program is a demo of how to use most of the functions
// of the library with ArduCAM ESP8266 5MP camera.
// This demo was made for ArduCAM ESP8266 OV5640 5MP Camera.
// It can take photo and send to the Web.
// It can take photo continuously as video streaming and send to the Web.
// The demo sketch will do the following tasks:
// 1. Set the camera to JEPG output mode.
// 2. if server.on("/capture", HTTP_GET, serverCapture),it can take photo and send to the Web.
// 3.if server.on("/stream", HTTP_GET, serverStream),it can take photo continuously as video
//streaming and send to the Web.
// This program requires the ArduCAM V4.0.0 (or later) library and ArduCAM ESP8266 5MP camera
// and use Arduino IDE 1.5.8 compiler or above
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include "memorysaver.h"
#if !(defined ESP8266 )
#error Please select the ArduCAM ESP8266 UNO board in the Tools/Board
#endif
//This demo can only work on OV5640_MINI_5MP_PLUS or ARDUCAM_SHIELD_V2 platform.
#if !(defined (OV5640_MINI_5MP_PLUS)||(defined (ARDUCAM_SHIELD_V2) && defined (OV5640_CAM)))
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
// set GPIO16 as the slave select :
const int CS = 16;
//you can change the value of wifiType to select Station or AP mode.
//Default is AP mode.
int wifiType = 1; // 0:Station  1:AP
//AP mode configuration
//Default is arducam_esp8266.If you want,you can change the AP_aaid  to your favorite name
const char *AP_ssid = "arducam_esp8266";
//Default is no password.If you want to set password,put your password here
const char *AP_password = "";
//Station mode you should put your ssid and password
const char* ssid = "SSID"; // Put your SSID here
const char* password = "PASSWORD"; // Put your PASSWORD here
ESP8266WebServer server(80);
ArduCAM myCAM(OV5640, CS);
void start_capture(){
  myCAM.clear_fifo_flag();
  myCAM.start_capture();
void camCapture(ArduCAM myCAM){
  WiFiClient client = server.client();
  size_t len = myCAM.read_fifo_length();
  if (len >= MAX_FIFO_SIZE){
    Serial.println("Over size.");
    return;
  }else if (len == 0 ){
    Serial.println("Size is 0.");
    return;
  myCAM.CS_LOW();
  myCAM.set_fifo_burst();
  #if !(defined (ARDUCAM_SHIELD_V2) && defined (OV5640_CAM))
  SPI.transfer(0xFF);
  #endif
  if (!client.connected()) return;
  String response = "HTTP/1.1 200 OK\r\n";
  response += "Content-Type: image/jpeg\r\n";
  response += "Content-Length: " + String(len) + "\r\n\r\n";
  server.sendContent(response);
  static const size_t bufferSize = 4096;
  static uint8_t buffer[bufferSize] = {0xFF};
  while (len) {
      size_t will_copy = (len < bufferSize) ? len : bufferSize;
      SPI.transferBytes(&buffer[0], &buffer[0], will_copy);
      if (!client.connected()) break;
      client.write(&buffer[0], will_copy);
      len -= will_copy;
  myCAM.CS_HIGH();
void serverCapture(){
  start_capture();
  Serial.println("CAM Capturing");
  int total_time = 0;
  total_time = millis();
  while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
  total_time = millis() - total_time;
  Serial.print("capture total_time used (in miliseconds):");
  Serial.println(total_time, DEC);
  total_time = 0;
  Serial.println("CAM Capture Done!");
  camCapture(myCAM);
  Serial.print("send total_time used (in miliseconds):");
  Serial.println("CAM send Done!");
void serverStream(){
  response += "Content-Type: multipart/x-mixed-replace; boundary=frame\r\n\r\n";
  while (1){
    start_capture();
      continue;
      continue;
    myCAM.CS_LOW();
    SPI.transfer(0xFF);
    #endif
    response = "--frame\r\n";
    response += "Content-Type: image/jpeg\r\n\r\n";
    while (len) {
      len -= will_copy;
    myCAM.CS_HIGH();
void handleNotFound(){
  String message = "Server is running!\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET)?"GET":"POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  server.send(200, "text/plain", message);
  if (server.hasArg("ql")){
    int ql = server.arg("ql").toInt();
    myCAM.OV5640_set_JPEG_size(ql);
    Serial.println("QL change to: " + server.arg("ql"));
  uint8_t vid, pid;
  uint8_t temp;
#if defined(__SAM3X8E__)
  Wire1.begin();
#else
  Wire.begin();
#endif
  Serial.println("ArduCAM Start!");
  // set the CS as an output:
  pinMode(CS, OUTPUT);
  // initialize SPI:
  SPI.begin();
  SPI.setFrequency(4000000); //4MHz
  //Check if the ArduCAM SPI bus is OK
  myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
  temp = myCAM.read_reg(ARDUCHIP_TEST1);
  if (temp != 0x55){
    Serial.println("SPI1 interface Error!");
    while(1);
  //Check if the camera module type is OV5640
  myCAM.wrSensorReg16_8(0xff, 0x01);
  myCAM.rdSensorReg16_8(OV5640_CHIPID_HIGH, &vid);
  myCAM.rdSensorReg16_8(OV5640_CHIPID_LOW, &pid);
   if((vid != 0x56) || (pid != 0x40)){
   Serial.println("Can't find OV5640 module!");
   while(1);
   Serial.println("OV5640 detected.");
  //Change to JPEG capture mode and initialize the OV5642 module
  myCAM.set_format(JPEG);
   myCAM.InitCAM();
   myCAM.write_reg(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);   //VSYNC is active HIGH
   myCAM.OV5642_set_JPEG_size(OV5640_320x240);delay(1000);
  if (wifiType == 0){
    if(!strcmp(ssid,"SSID")){
       Serial.println("Please set your SSID");
       while(1);
    if(!strcmp(password,"PASSWORD")){
       Serial.println("Please set your PASSWORD");
       while(1);
    // Connect to WiFi network
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.mode(WIFI_STA);
    WiFi.begin(ssid, password);
      Serial.print(".");
    Serial.println("WiFi connected");
    Serial.println("");
  }else if (wifiType == 1){
    Serial.print("Share AP: ");
    Serial.println(AP_ssid);
    Serial.print("The password is: ");
    Serial.println(AP_password);
    WiFi.mode(WIFI_AP);
    WiFi.softAP(AP_ssid, AP_password);
    Serial.println("");
    Serial.println(WiFi.softAPIP());
  // Start the server
  server.on("/capture", HTTP_GET, serverCapture);
  server.on("/stream", HTTP_GET, serverStream);
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.println("Server started");
  server.handleClient();
that when I open the serial monitor I get this error
Soft WDT reset
ctx: cont
sp: 3fff1fb0 end: 3fff21c0 offset: 01b0
>>>stack>>>
3fff2160:  3fffdad0 3fff1164 3fff1164 40202a60
3fff2170:  feefeffe feefeffe feefeffe feefeffe
3fff2180:  feefeffe feefeffe feefeffe feefeffe
3fff2190:  feefeffe feefeffe feefeffe 3fff1190
3fff21a0:  3fffdad0 00000000 3fff1188 40208220
3fff21b0:  feefeffe feefeffe 3fff11a0 40100710
<<<stack<<<
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v614f7c32
~ld
ArduCAM Start!
. The project is to connect the OV5640 camera to the NodeMCU module by SPI. It is probable that the connection has it badly done since I can not find anywhere that pins are the SPI communication of the OV5640 camera. If anyone knows something that helps me.
Is this really a bootloader issue?
It seems to me more likely that you have a busy-wait that shouldn't be there.
i dont understand you
Ivan10fcb:
What makes you think this is a bootloader issue?
Your code has loaded and started to run, so the bootloader must have already done its job.
I think I did not say that the problem is with the bootloader. But I do not know what the problem is.
Ivan10fcb:
So why did you post this problem in the section of the forum dealing with bootloader issues?
