Spi interrupt issue
HI all ,
i am using RPI4 and two Arduino nano 33 iot using spi connection
i shared miso mosi sck but while i am running heartbeat check function on 1 Arduino but i am getting clock interrupt on second Arduino even though chip select connections is not there
pinMode(slaveAPin, INPUT_PULLUP);
//attachInterrupt(digitalPinToInterrupt(slaveAPin), SERCOM1_Handler, FALLING);
spiSlave_init();
this function is running continuedly but it is comment how it is running
PORT->Group[PORTA].PINCFG[16].bit.PMUXEN = 0x1; // Enable Peripheral Multiplexing for SERCOM1 SPI PA18 Arduino PIN10
PORT->Group[PORTA].PMUX[8].bit.PMUXE = 0x2; // SERCOM 1 is selected for peripherial use of this pad
PORT->Group[PORTA].PINCFG[17].bit.PMUXEN = 0x1; // Enable Peripheral Multiplexing for SERCOM1 SPI PA18 Arduino PIN10
PORT->Group[PORTA].PMUX[8].bit.PMUXO = 0x2; // SERCOM 1 is selected for peripherial use of this pad
PORT->Group[PORTA].PINCFG[21].bit.PMUXEN = 0x1; // Enable Peripheral Multiplexing for SERCOM1 SPI PA18 Arduino PIN10
PORT->Group[PORTA].PMUX[9].bit.PMUXE = 0x2; // SERCOM 1 is selected for peripherial use of this pad
PORT->Group[PORTA].PINCFG[19].bit.PMUXEN = 0x1; // Enable Peripheral Multiplexing for SERCOM1 SPI PA18 Arduino PIN10
PORT->Group[PORTA].PMUX[9].bit.PMUXO = 0x2; // SERCOM 1 is selected for peripherial use of this pad
// Disable SPI 1
SERCOM1->SPI.CTRLA.bit.ENABLE = 0;
while (SERCOM1->SPI.SYNCBUSY.bit.ENABLE)
// Reset SPI 1
SERCOM1->SPI.CTRLA.bit.SWRST = 1;
while (SERCOM1->SPI.CTRLA.bit.SWRST || SERCOM1->SPI.SYNCBUSY.bit.SWRST)
// Setting up NVIC
NVIC_EnableIRQ(SERCOM1_IRQn);
NVIC_SetPriority(SERCOM1_IRQn, 2);
// Setting Generic Clock Controller!!!!
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID(GCM_SERCOM1_CORE) | // Generic Clock 0
GCLK_CLKCTRL_GEN_GCLK0 | // Generic Clock Generator 0 is the source
GCLK_CLKCTRL_CLKEN; // Enable Generic Clock Generator
while (GCLK->STATUS.reg & GCLK_STATUS_SYNCBUSY)
; // Wait for synchronisation
// Set up SPI Control A Register
SERCOM1->SPI.CTRLA.bit.DORD = 0; // MSB first
SERCOM1->SPI.CTRLA.bit.CPOL = 0; // SCK is low when idle, leading edge is rising edge
SERCOM1->SPI.CTRLA.bit.CPHA = 0; // data sampled on leading sck edge and changed on a trailing sck edge
SERCOM1->SPI.CTRLA.bit.FORM = 0x0; // Frame format = SPI
SERCOM1->SPI.CTRLA.bit.DIPO = 0x0; // DATA PAD0 MOSI is used as input (slave mode)
SERCOM1->SPI.CTRLA.bit.DOPO = 0x2; // DATA PAD3 MISO is used as output
SERCOM1->SPI.CTRLA.bit.MODE = 0x2; // SPI in Slave mode
SERCOM1->SPI.CTRLA.bit.IBON = 0x1; // Buffer Overflow notification
SERCOM1->SPI.CTRLA.bit.RUNSTDBY = 1; // wake on receiver complete
// Set up SPI control B register
// SERCOM1->SPI.CTRLB.bit.RXEN = 0x1; //Enable Receiver
SERCOM1->SPI.CTRLB.bit.SSDE = 0x1; // Slave Selecte Detection Enabled
SERCOM1->SPI.CTRLB.bit.CHSIZE = 0; // character size 8 Bit
SERCOM1->SPI.CTRLB.bit.PLOADEN = 0x1; // Enable Preload Data Register
while (SERCOM1->SPI.SYNCBUSY.bit.CTRLB)
// Set up SPI interrupts
SERCOM1->SPI.INTENSET.bit.SSL = 0x1; // Enable Slave Select low interrupt
SERCOM1->SPI.INTENSET.bit.RXC = 0x1; // Receive complete interrupt
SERCOM1->SPI.INTENSET.bit.TXC = 0x0; // Receive complete interrupt
SERCOM1->SPI.INTENSET.bit.ERROR = 0x0; // Receive complete interrupt
SERCOM1->SPI.INTENSET.bit.DRE = 0x0; // Data Register Empty interrupt
// init SPI CLK
// SERCOM1->SPI.BAUD.reg = SERCOM_FREQ_REF / (2*4000000u)-1;
// Enable SPI
SERCOM1->SPI.CTRLA.bit.ENABLE = 1;
SERCOM1->SPI.CTRLB.bit.RXEN = 0x1; // Enable Receiver, this is done here due to errate issue
; // wait until receiver is enabled
what i need to change here please help me if any one have any idea about this ?
I moved your topic to an appropriate forum category @sachinn434434.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
