I am an arduino newbie so know nothing and am hoping begging for some advice will help me get kick started.....
Basically I have not done anything yet as I want to be sure it is possible before starting coding .
I worry I will look stupid as I maybe ask the impossible or should have done some research first, I show below my pseudocode/thoughts/ideas/system description, but will ask my questions first...
How can I setup dma on arduino to handle SPI (does arduino even have dma for SPI as slave??) i have seen this http://arduino.cc/forum/index.php?PHPSESSID=3224079b565191d380db0d82da085c82&topic=147858.0, but no mention of dma..
How fast can arduino handle dma and interupts and what are speed considerations?, i.e. what is the shortest usleep in the main loop that can guarantee a constant step rate?
Is there any example code of similar projects available?
System definition:
Arduino as SPI slave that works as a digital IO interface (basically constant step rate switching gpio pins dependent on SPI data)
- The arduino must take SPI packets of data (64 bytes I guess) as fast as possible
- store SPI data in memory
- constantly step through memory and switching IO pins
- flag SPI master if it runs out of data
- (possibly in future add some code for config the arduino via SPI e.g change step rate, number of io pins being switched etc..)
I am guessing what I need to do is
allocate 3 64 byte buffers
setup arduino dma to write SPI data to buffers (double buffering)
create interupt to rotate through the buffer when SPI dma completes
write the data output loop
I am assuming arduino has dma for SPI and it can be setup for 64 byte packets, I have not found any information about SPI dma yet??????
outline pseudo code below :
current_buffer = 0; // pointer indexing where we are for comparison purposes
dma_buffer = 0; // pointer to where SPI data is buffered by dma
out_buffer = -1; // pointer to buffer currently being read to output pins
setup_dma(); // function, how do we setup dma to copy 64 bytes from SPI to a memory buffer?????
// I imagine interupt routine should be similar to below:
interupt_service_routine()
// update circular buffer index
If (current_buffer == 3) current_buffer = 0 ;
else current_buffer = current_buffer + 1 ;
if(current_buffer==out_buffer) halt_spi_master(); // stop if we are going to over write the current output
if(current_buffer==3 & out_buffer==-1 ){ main_loop(); current_buffer=0; } // start the main loop once 3 buffers full
dma_buffer = current_buffer;
// I imagine the output loop should be similar to that below:
out_buffer=0;
main_loop()
DDRB = b11111111 ; // set portB output direction
for(;![]()
PORTB= out_buffer[index]
index++;
usleep(step_time);
if(index==64) {
index=0;
If (out_buffer == 3) out_buffer = 0 ;
else out_buffer = out_buffer + 1 ;
if(out_buffer==dma_buffer) halt_master_flag_underrun();
