SPI LCD (U8G2) with SPI Counter Connection Issue
Hey Guys,
I’m using a ProMini to run a small rotary encoder counter and display project. The encoder pulses are going to an LS7366 counter via SPI. I Initially set this up using the SPI counter and an I2C OLED display and everything functioned perfectly but the display is unreadable when using in bright outdoors. So I wanted to switch to this JLX12864G-08602 SPI COG display using the U8G2 library.
I had no issues with my code when running the counter with the I2C display but I cannot figure out what I’m doing wrong with connecting multiple SPI devices.
I think I have everything wired up correctly because I can get a string to appear whenever I do not call the LS7366 to connect.
It looks like whenever I initialize the encoder chip and SPI.begin(), I loose the LCD communication.
Is there an Issue with using the u8g2 library and my LS7366 chip?
I would really appreciate any help on this… Been working days trying to figure this one out.
Here is my sketch below:
#include <Arduino.h>
#include <U8g2lib.h>
#include <SPI.h>
int chipSelectPin1=10;
//-===============================DISPLAY SETTINGS =======================================
U8G2_UC1701_MINI12864_F_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 2, /* dc=*/ 3, /* reset=*/ 4);
  u8g2.begin();
  pinMode(chipSelectPin1, OUTPUT);
  digitalWrite(chipSelectPin1, HIGH); // Pin for chip select SPI for encoder
 LS7366_Init();
  delay(100);
 long encoder1Value;
 encoder1Value = getEncoderValue(1); // Get the pulse count from the encoder
delay(50);
 u8g2.clearBuffer();          // clear the internal memory
  u8g2.setFont(u8g2_font_logisoso30_tn);  // choose a suitable font
  u8g2.drawStr(0,50,encoder1Value); // write something to the internal memory
  u8g2.sendBuffer();          // transfer internal memory to the display
  delay(50);
}//end void loop
long getEncoderValue(int encoder)
    unsigned int count1Value, count2Value, count3Value, count4Value;
    long result;
    selectEncoder(encoder);
    SPI.transfer(0x60); // Request count
    count1Value = SPI.transfer(0x00); // Read highest order byte
    count2Value = SPI.transfer(0x00);
    count3Value = SPI.transfer(0x00);
    count4Value = SPI.transfer(0x00); // Read lowest order byte
    deselectEncoder(encoder);
    result= ((long)count1Value<<24) + ((long)count2Value<<16) + ((long)count3Value<<8) + (long)count4Value;
    return result;
void selectEncoder(int encoder)
        digitalWrite(chipSelectPin1,LOW);
void deselectEncoder(int encoder)
        digitalWrite(chipSelectPin1,HIGH);
void LS7366_Init(void)  // LS7366 Initialization and configuration
    // SPI initialization
    SPI.begin();
    //SPI.setClockDivider(SPI_CLOCK_DIV16);      // SPI at 1Mhz (on 16Mhz clock)
    delay(10);
   SPI.transfer(0x88);        // Enable write to first byte of chip- MDR0
   SPI.transfer(0x01);        // set quadrature mode
Usually you can not combine Software emulated (bitbanging) SPI with Hardware driven SPI:
Instead of
try
U8G2_UC1701_MINI12864_F_4W_HW_SPI u8g2(U8G2_R0,/* cs=*/ 2, /* dc=*/ 3, /* reset=*/ 4);
This will also speed up refresh rate for the LCD.
Oliver
Ok, I will try it as soon as I get back to the office today..
I noticed in your reply that you have omitted Clock and Data in the constructor for Hardware SPI, it that correct?
Thanks again,
Vince
Yes, because SPI pins are fixed. I guess you also did not use any pins for the communication with the LS7366 :wink:
Oliver
Thanks a Million,
Everything is working great!
