SPI Lib for VDrive2
G'Day
Does anyone know where I can get a SPI library for the VDrive. The posts I have seen all use the serial mode for data transfer
Tks
Probably because they do a proprietary screw you to the SPI standard
http://www.vinculum.com/documents/datasheets/DS_VNC1L_V201(FT_000030).pdf
Yup, was only thinking about using SPI as I have it set up for the MAX7219. But with NewSoftSerial Lib the Vdrive serial option will only add other 2 pins, so will go the serial way. Tks
