Hi All,
New to this forum but I wanted to post an issue I am having with the SPI library. I have been using the SPI library with the Arduino Due. I needed to move to a faster processor so I setup an Intel Edison to use in the Arduino IDE. My sketch no longer compiles with the Intel Edison as the target (blink example does compile). Has anyone else encountered this problem? I get the following error messages:
-Joel
BalanceBeamSketch:83: error: 'SPISettings' does not name a type
SPISettings myA2DSettings(A2D_SCK_RATE, MSBFIRST, SPI_MODE0);
BalanceBeamSketch:84: error: 'SPISettings' does not name a type
SPISettings myD2ASettings(D2A_SCK_RATE, MSBFIRST, SPI_MODE0);
BalanceBeamSketch:85: error: 'SPISettings' does not name a type
SPISettings myUFDCSettings(UFDC_SCK_RATE, MSBFIRST, SPI_MODE3); // SPI_MODE3
C:\Users\shields\Documents\Arduino\sketches\BalanceBeamSketch\BalanceBeamSketch.ino: In function 'float read_A2D_voltage()':
BalanceBeamSketch:459: error: 'class SPIClass' has no member named 'beginTransaction'
SPI.beginTransaction(myA2DSettings); // SPI_MODE0 15150000
BalanceBeamSketch:459: error: 'myA2DSettings' was not declared in this scope
BalanceBeamSketch:469: error: 'class SPIClass' has no member named 'transfer16'
recieved_val = SPI.transfer16(data);
BalanceBeamSketch:471: error: 'class SPIClass' has no member named 'endTransaction'
SPI.endTransaction();
C:\Users\shields\Documents\Arduino\sketches\BalanceBeamSketch\BalanceBeamSketch.ino: In function 'void send_D2A_voltages(float*, float*)':
BalanceBeamSketch:503: error: 'class SPIClass' has no member named 'beginTransaction'
SPI.beginTransaction(myD2ASettings);
BalanceBeamSketch:503: error: 'myD2ASettings' was not declared in this scope
BalanceBeamSketch:505: error: 'class SPIClass' has no member named 'transfer16'
SPI.transfer16(data1);
BalanceBeamSketch:512: error: 'class SPIClass' has no member named 'transfer16'
SPI.transfer16(data2);
BalanceBeamSketch:514: error: 'class SPIClass' has no member named 'endTransaction'
C:\Users\shields\Documents\Arduino\sketches\BalanceBeamSketch\BalanceBeamSketch.ino: In function 'void read_UFDC(float*, int)':
BalanceBeamSketch:540: error: 'class SPIClass' has no member named 'beginTransaction'
SPI.beginTransaction(myUFDCSettings); // 100 - 500 kHz
BalanceBeamSketch:540: error: 'myUFDCSettings' was not declared in this scope
BalanceBeamSketch:590: error: 'class SPIClass' has no member named 'endTransaction'
BalanceBeamSketch:621: error: 'class String' has no member named 'toFloat'
*UFDC_sig = inString.toFloat();
exit status 1
