SPI master and slave
Hello, I am a new user of arduino, I wanted to make a communication between 2 arduinos. So by looking on this forum I found very intersting links on this subject but it is always a little blurry. do I have the right to use "proteus" for the simulation? And I wanted to see the msg exchanged between the two microcontrollers ..
NB: I use simulation because the cards I bought have not come yet.
Thank you for helping me.
The links I found:
Http://www.gammon.com.au/forum/?id=10892 Https://forum.arduino.cc/index.php?topic=120049.15
You would need to ask that on the useless simulator forum.
OK, so I misspelled proteus. Big deal.
You can use a logic analyzer or an oscilloscope to see the exchange of data between the two arduino boards. The oscilloscope I use will actually display the byte sent using the SPI protocol. This is a feature of many logic analyzers.
Of course, you can also do this by hand: at each rising edge, note whether the MOSI or MISO line is HIGH(1) or LOW(0). Then combine the string of 1's and 0's to form a byte. Then reference the ascii table.
yes,
you can use. connect SPI debugger, connect the logic analyzer, connect the oscilloscope in SPI pins.
