Here I use 3 arduino slaves. (But In the future I will use 5 slaves)
// master
#include <SPI.h>
#define SS_1 7
#define SS_2 8
#define SS_3 6
//#define SS_4 5
//#define SS_5 4
void setup (void)
Serial.begin (115200);
Serial.println ("Starting");
pinMode(SS_1, OUTPUT);
pinMode(SS_2, OUTPUT);
// pinMode(SS_3, OUTPUT);
// pinMode(SS_4, OUTPUT);
// pinMode(SS_5, OUTPUT);
digitalWrite(SS_1, LOW); // ensure SS stays high for now
digitalWrite(SS_2, LOW); // ensure SS stays high for now
digitalWrite(SS_3, LOW); // ensure SS stays high for now
// digitalWrite(SS_4, LOW); // ensure SS stays high for now
// digitalWrite(SS_5, LOW); // ensure SS stays high for now
SPI.begin ();
SPI.setClockDivider(SPI_CLOCK_DIV128);
void loop (void)
char buf_1[54]; //54
char buf_2[54]; //54
// char buf_3[54]; //54
// char buf_4[54]; //54
// char buf_5[54]; //54
digitalWrite(SS_1, HIGH );
SPI.transfer (1);
for (int pos = 0; pos < sizeof (buf_1) - 1; pos++)
delayMicroseconds (20);
buf_1 [pos] = SPI.transfer (0);
if (buf_1 [pos] == 0)
buf_1 [sizeof (buf_1) - 1] = 0;
Serial.print("Slave 1:");
Serial.print(buf_1);
memset(buf_1, 0, sizeof(buf_1)); //clear array
delay(10);
delay(10);
Serial.print("\t");
//================SLAVE 2===================//
digitalWrite(SS_2, HIGH);
SPI.transfer (2);
for (int pos = 0; pos < sizeof (buf_2) - 1; pos++)
buf_2 [pos] = SPI.transfer (0);
if (buf_2 [pos] == 0)
buf_2 [sizeof (buf_2) - 1] = 0;
Serial.print("Slave 2:");
Serial.print(buf_2);
memset(buf_2, 0, sizeof(buf_2)); //clear array
delay(10);
Serial.print("\t");
//================SLAVE 3===================//
// digitalWrite(SS_3, HIGH);
// SPI.transfer (3);
// for (int pos = 0; pos < sizeof (buf_3) - 1; pos++)
// delayMicroseconds (20);
// buf_3 [pos] = SPI.transfer (0);
// if (buf_3 [pos] == 0)
// break;
// buf_3 [sizeof (buf_3) - 1] = 0;
// Serial.print("Slave 3:");
// Serial.print(buf_3);
// memset(buf_3, 0, sizeof(buf_3)); //clear array
// delay(10);
// digitalWrite(SS_3, LOW);
// Serial.print("\t");
//================SLAVE 4===================//
// digitalWrite(SS_4, HIGH);
// SPI.transfer (4);
// for (int pos = 0; pos < sizeof (buf_4) - 1; pos++)
// buf_4 [pos] = SPI.transfer (0);
// if (buf_4 [pos] == 0)
// break;
// buf_4 [sizeof (buf_4) - 1] = 0;
// Serial.print("Slave 4:");
// Serial.print(buf_4);
// memset(buf_4, 0, sizeof(buf_4)); //clear array
// delay(10);
// //================SLAVE 5===================//
// digitalWrite(SS_5, HIGH);
// SPI.transfer (5);
// for (int pos = 0; pos < sizeof (buf_5) - 1; pos++)
// buf_5 [pos] = SPI.transfer (0);
// if (buf_5 [pos] == 0)
// break;
// buf_5 [sizeof (buf_5) - 1] = 0;
// Serial.print("Slave 5:");
// Serial.print(buf_5);
// memset(buf_5, 0, sizeof(buf_5)); //clear array
// delay(10);
Serial.println("");
} // end of loop
// Slave
#include <Wire.h>
#include <VL53L1X.h>
//#define max_range 1000
//#define min_range 20
#define XSHUT_1 3
VL53L1X sensor1;
//uint8_t value1;
volatile char buf[54];
volatile int pos;
volatile bool active;
void setup (void)
int x;
int i;
int j;
int jaraktotal;
unsigned long t;
unsigned long tx;
unsigned long ty;
while (!Serial) {}
Wire.begin();
Wire.setClock(400000); // use 400 kHz I2C
pinMode(MISO, OUTPUT);
pinMode(XSHUT_1, OUTPUT);
digitalWrite(XSHUT_1, LOW);
SPCR |= bit(SPE);
SPCR |= bit(SPIE);
//Conf. Sensor1
delay(50);
digitalWrite(XSHUT_1, HIGH);
delay(50);
sensor1.setTimeout(500);
if (!sensor1.init())
Serial.println("Failed to detect and initialize sensor1!");
else {
sensor1.setAddress(24);
sensor1.setDistanceMode(VL53L1X::Long);
sensor1.setMeasurementTimingBudget(23500); //microsecond => 10 milisecond = 10ms
sensor1.startContinuous(45);
sensor1.setROISize(1, 8);
ISR (SPI_STC_vect)
byte c = SPDR;
if (c == 3) { //different value for every string
active = true;
pos = 0;
SPDR = buf [pos++];
return;
if (!active)
SPDR = 0;
return;
SPDR = buf [pos];
if (buf [pos] == 0 || ++pos >= sizeof(buf))
active = false;
void loop (void)
int x = 0;
// int hitung = 0;
int hasil[13] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12};
for (int i = 151; i <= 247;) {
sensor1.setROICenter(i);
sensor1.startContinuous(10);
hasil[x] = sensor1.read();
Serial.print(hasil[x]);
Serial.print(",");
x++;
i += 8;
Serial.println("");
sprintf(buf, "%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,%d,", hasil[0],hasil[1],hasil[2],hasil[3],hasil[4],hasil[5],hasil[6],hasil[7],hasil[8],hasil[9],hasil[10],hasil[11],hasil[12]);
but the new problem is I can not read the data from the slave 3. I succeed to read data from slave 1 and 2, but when I activate slave 3 I got problem and the output is unwanted characters. When I tried between slave 2 and slave 3 it only showed me the output of slave 3. I wonder what happened and what's wrong with my code? Thank you
