SPI multiples devices- Sd card - help
because if I disconnect the cable , Slave Select pin Cs , the sd card is working
the sd card is working?
I give up. Was it?
PaulS:
I give up. Was it?
You are asking us if your SD card was working. You have the software and the hardware. You should know whether it was working. All we have is the information you provide. There was nothing in that information that allows us to know whether the SD card was working, or not.
PaulS:
i am stating: "I disconnect the cord, Slave Select pin cs"
because the Sd card, still working?
