SPI on Arduino Nano 33 BLE Sense
I'm trying to figure out how to use I2C and SPI at the same time on Arduino Nano 33 BLE Sense.
Is it 10,11,12,13 as on regular Arduino?
In case it is, I think it would be helpful to update:https://content.arduino.cc/assets/Pinout-NANOsense_latest.pdf
To reflect use of SPI
yes it is 11, 12, 13 as on classic Nano. you can choose any pin as CS
Tested with Nano BLE sense with MKR ENV shield for SPI and I2C at a same time.
//SPI connection tested the files in the SD card
D11 - Mosi
D12 - Miso
D13 - SCK
D4 - D4 // for CS connection
3.3V - Vcc
Gnd to Gnd
// I2C connection tested to read the values from the sensors.
GND - GND
3.3V - VCC
A4 - 11
A5 - 12
//Arduino
bergstar:
did they update or you didn't see the MOSI, MISO, SCK, SDA and SCL labels?
Since the Nano 33 BLE Sense runs mbed OS, were you able to use the Arduino SD library or did you have to use "SDFileSystem.h" or "SDBlockDevice.h" from mbed?
In either case, I would love to see a minimal sketch showing reading and writing to a file on an SD Card using the Nano 33 BLE Sense
I understand that CS / SS can use any digital pin on the Nano boards. I purchased a open source production SD / RTC shield but it fails "initialization" using PIN 4 or PIN 10 for several example sketched.
What PIN number (on the Nano 33 ioT) is hard wired to connect CS / SS?
I have not been able to find the shield's schematic.
Thanks
Wagsalot:
Thanks
any pin
no hardwired
schematics are in STORE
