I understand the DUE uses SPI(0) with CS options of 4,10,52.
what pins do i use for CS if i want to use SPI(1) instead? could you share example of code to write byte and blocks?
[SPI(1) is the other dual row 6 pin header between MPU and power adapter port]- i have specific reason to want separate MOSI and SCLK lines.
thanks
You mean the ICSP put there for programming the ATMega16U2? That's not connected to the main processor.
The Due can run SPI on any of the USARTS - that's most of the additional serial ports. If you can give up a serial port then you can run hardware SPI on those. I haven't seen a library to do this but I think it's possible to do without throwing away to much of the Arduino framework.
SPI1 - only available on the SAM3X8H (217 pin) which is not commercially available but was used on an Atmel evaluation board. Compare pages 6 and 7 in the datasheet (lower right corner of diagram).
