Hello,
I've been attempting to use SERCOM2 SPI Master on the SAMD21G18J but have been unsuccessful. I tried the configurations with SERCOM0 and SERCOM4, and they both worked. The most intriguing behavior is that when I initialize the SERCOM2 SPI, all of the other I/O pins stop working as well. The clock is not generated, and CS is not operational.
I tried several bootloaders, but the results were the same. To begin, I used the bootloader of an Arduino nano IOT 33, which uses the same chip, in order to use the arduino IDE more easily. Then, I tested with the bootloaders Arduino zero and adafruit M0 bootloader. The idea of testing other bootloarders was because arduino ano iot 33 uses SPI SERCOM2 to communicate with his WIFI module, and could be protected some how. Any insight will be useful.
The schematic is displayed below:
The SERCOM2 Pads:
Main routine:
// inslude the SPI library:
#include <SPI.h>
#include "SercomSPISlave.h"
SercomSPIMaster Spi2;
PORT->Group[PORTA].DIR.reg |= PORT_PA08; // Output set wifi ctrl
PORT->Group[PORTA].OUT.reg &= ~PORT_PA08; // Turn OFF wifi
// PORT->Group[PORTA].OUTCLR.reg |= PORT_PA08;
PORT->Group[PORTA].DIR.reg |= PORT_PA04; // set output Group; Turn-On Circuit;
PORT->Group[PORTA].OUT.reg |= PORT_PA04;
PORT->Group[PORTA].OUTSET.reg |= PORT_PA04; // Turn ON
PORT->Group[PORTA].DIR.reg |= PORT_PA14; // set CS output
pinMode(4, OUTPUT);
// set the slaveSelectPin as an output:
pinMode (slaveSelectPin, OUTPUT); //spi1
// initialize SPI:
Spi2.Sercom2Masterinit(); //spi2
char c='z', r;
PORT->Group[PORTA].OUT.reg &= ~PORT_PA14; // Turn OFF wifi
delay(100);
// send in the address and value via SPI:
r= Spi2.transfer2(c); //spi1
Serial.println(r);
delay(100);
// take the SS pin high to de-select the chip:
PORT->Group[PORTA].OUTSET.reg |= PORT_PA14; // Turn ON; unset pin
//delay(1000);
Header file:
void SercomSPIMaster::Sercom2Masterinit(){
PORT->Group[PORTA].DIR.reg &= ~PORT_PA13; //Set as input (MISO)
PORT->Group[PORTA].DIR.reg |= PORT_PA15; //Set as output (SCK)
PORT->Group[PORTA].DIR.reg |= PORT_PA14; //Set as output (SS)
PORT->Group[PORTA].DIR.reg |= PORT_PA12; //Set as output (MOSI)
pin_set_peripheral_function(PINMUX_PA15C_SERCOM2_PAD3);
pin_set_peripheral_function(PINMUX_PA14C_SERCOM2_PAD2);
pin_set_peripheral_function(PINMUX_PA13C_SERCOM2_PAD1);
pin_set_peripheral_function(PINMUX_PA12C_SERCOM2_PAD0);
//PAGE 492 26.8.1 Control A - ref B
SERCOM2->SPI.CTRLA.bit.ENABLE =0; //Disable SPI 1
while(SERCOM2->SPI.SYNCBUSY.bit.ENABLE); // Wait sync
//Reset SPI 1
SERCOM2->SPI.CTRLA.bit.SWRST = 1;
while(SERCOM1->SPI.CTRLA.bit.SWRST || SERCOM1->SPI.SYNCBUSY.bit.SWRST); // Wait sync
//Setting Generic Clock Controller!!!!
GCLK->CLKCTRL.reg = GCLK_CLKCTRL_ID(GCM_SERCOM1_CORE) | //Generic Clock 0
GCLK_CLKCTRL_GEN_GCLK0 | // Generic Clock Generator 0 is the source
GCLK_CLKCTRL_CLKEN; // Enable Generic Clock Generator
while(GCLK->STATUS.reg & GCLK_STATUS_SYNCBUSY); //Wait for synchronisation
//Set up SPI Control A Register
SERCOM2->SPI.CTRLA.bit.DORD = 0; //MSB first
SERCOM2->SPI.CTRLA.bit.CPOL = 0; //SCK is low when idle, leading edge is rising edge
SERCOM2->SPI.CTRLA.bit.CPHA = 0; //data sampled on leading sck edge and changed on a trailing sck edge
SERCOM2->SPI.CTRLA.bit.FORM = 0x0; //Frame format = SPI
// Choose PAD configuration
SERCOM1->SPI.CTRLA.bit.DIPO = 0x1; //DATA PAD1 MISO is used as Master input (slave mode) // page 492
SERCOM1->SPI.CTRLA.bit.DOPO = 0x3; //DATA PAD0 MOSI is used as Master output and PAD3 as SCK
SERCOM2->SPI.CTRLA.bit.MODE = 0x3; //SPI in Master mode
SERCOM2->SPI.CTRLA.bit.IBON = 0x1; //Buffer Overflow notification
SERCOM2->SPI.CTRLA.bit.RUNSTDBY = 1; //wake on receiver complete
//Set up SPI control B register
SERCOM2->SPI.CTRLB.bit.RXEN = 0x1; //Enable Receiver
//SERCOM2->SPI.CTRLB.bit.SSDE = 0x1; //Slave Selecte Detection Enabled
SERCOM2->SPI.CTRLB.bit.CHSIZE = 0; //character size 8 Bit
//SERCOM1->SPI.CTRLB.bit.PLOADEN = 0x1; //Enable Preload Data Register
//while (SERCOM1->SPI.SYNCBUSY.bit.CTRLB);
//Set Baud rate
uint16_t BAUD_REG = ((float)SPI_CLK_FREQ / (float)(2 * SPI_BAUD)) - 1; //Calculate BAUD value For Sync
SERCOM2->SPI.BAUD.reg = SERCOM_SPI_BAUD_BAUD(BAUD_REG); //Set the SPI baud rate
SERCOM2->SPI.CTRLA.reg |= SERCOM_SPI_CTRLA_ENABLE; //Enable the Sercom SPI
//Enable SPI
SERCOM2->SPI.CTRLA.bit.ENABLE = 1;
SERCOM2->SPI.CTRLB.bit.RXEN = 0x1; //Enable Receiver, this is done here due to errate issue
while(SERCOM2->SPI.SYNCBUSY.bit.CTRLB); //wait until receiver is enabled
uint8_t SercomSPIMaster::transfer2(uint8_t data)
while(SERCOM2->SPI.INTFLAG.bit.DRE == 0);
SERCOM2->SPI.DATA.reg = data;
while(SERCOM2->SPI.INTFLAG.bit.RXC == 0);
return (uint8_t)SERCOM2->SPI.DATA.reg;
