SPI over longer distance
I have some RFID readers type MFRC-522 and a Arduino Mega2560. The communication between MFRC522 and Arduino is over the SPI protocol. When I use short cables (+/- 10cm) it works fine, but I want to install the readers at +/- 7 meter from the location of the Arduino.
I read something about an convertor to RS422 like the MAX485.
Has somebody experience with this device, and will it work for my project, as describe above.
Thanks
Forget it. SPI is a local bus with a maximum length of about 40cm. You might get it to a meter or so by slowing down the bus significantly but I doubt you get it running over 7m at a reasonable speed.
Spend another Arduino, use it to control the reader and use a communication system in between it and the Mega2560 that is suited for such lengths (Ethernet, RS-485, etc.)
Hi Pylon,
Meanwhile I have done that. I bought 4 Arduino Nano, and 5 Max485 Modules. I connected the RFID reader to the Nano with the SPI protocol, and connected the Max485 to the nano and the Mega. I wrote a polling protocol to communicate between the 5 arduino's.
It works fine now.
Consider using a Nano or something similar at each node and communicate with the RS422 or RS485. It will not add much cost and give you a reliable system. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
