My sketch uses nRF24L01, Ethernet shield with SD card on the SPI bus, each having it's own SS (4 SD, 10 Ethernet, 8 nRF24L01).
I use Arduino libraries ( SD, Ethernet) and Mirf library to drive these devices. Each is device is running fine, doing it's job....
BUT, since I added the nRF24L01 device, I noticed a slow down in my transferts from/to Ethernet and SD card...
Each operation takes twice the time it took before this module... I looked inside the Mirf library and seen the "SPI.setClockDivider(SPI_2XCLOCK_MASK);" line.
My question are :
is it possible that this line cut SPI performance down to half ?
2 is it possible to change this setting ?
in case of negative answer to 2), is it possible to have a second SPI bus ?
in case of positive answer to 3), how could I do ?
Is there another answer to my performance problem
Thanks for your answer
Pierre
Yes, it's even quite probable that it cuts down even more. This is because
#define SPI_2XCLOCK_MASK 0x01 // SPI2X = bit 0 on SPSR
and the correct constant with the same value is
#define SPI_CLOCK_DIV16 0x01
So the SPI bus is running with 1MHz instead of 4MHz.
Yes, but not in the nRF24L01 library but you can change it back to the default value of SPI_CLOCK_DIV4 just before and call to the Ethernet or SD libraries. If you increase the speed in the nRF24L01 library you might get a too fast speed for the device and it won't operate anymore or be at least less reliable.
Not in hardware (on Arduinos).
You could do it in software but this will be much slower, so this is probably no option for you.
SPI.setClockDivider(SPI_CLOCK_DIV4);
do want I want.... And everything came as it was before !!!!!!!!!!!!!!!
SPI.setClockDivider(SPI_CLOCK_DIV16);
Mirf library is cutting SPI clock by 4... and everything using SPI bus is slowed seriously, but this module is so cheap and so easy to use !!!!!!!!!
