SPI Port - Send Data to a shift register - LSB first
Hi folks,
Not sure if here is the right place, but multiplexing = SPI + shift register... :wink:
I am sending data using SPI to a few shift registers, to have a paralel output.
PORTD &= ~_BV(4);                      //Turn Shift register CS PIN LOW); // connects to RCLK
SPI.transfer (highByte (output+results));        // send out upper 8 bits MSB first
SPI.transfer (lowByte (output+results));         // send out lower 8 bits
PORTD |= _BV(4);                       //Turn Shift register CS PIN high - data output changes on this rising edge
This sends the MSB first, however I wish to send the LSB first. How can this be achieved?
Regards
Thanks.
The correct syntax is:
SPI.begin();
SPI.setBitOrder(LSBFIRST);
void loop(){
 SPI.transfer (highByte (data));        // send out upper 8 bits MSB first
 SPI.transfer (lowByte (data));         // send out lower 8 bits
 PORTD |= _BV(4);                       //Turn Shift register CS PIN high - data output changes on this rising ed}
